Thread: Why is Vx so tight?
    Oct 2010
    Lincoln
    Default Why is Vx so tight?
    Tried to fit a rear interior light to my 56 plate SRi but was amazed to find that Vx hadn't bothered to put the loom in with the required plug OK so fairly easy to wire from the front light but for the sake of a couple of quid why not put the wiring in anyway!!
    And why don't I get info messages telling me the washers are low yet it tells me when temp is icy and my bulbs have blown!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    One of the reasons I love my 53 plate, it has nearly everything. Most cars get equipment added over the years, the Vec/Signum seemed to lose it
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Makes no sence to me either. Youd think it would be cheaper over the long run just to produce one wiring loom, especially the roof loom, then they would only have to stock one loom instead of 4 or 5 different ones.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I had the same problem, I used to have a 57 plate SRI 120 company car but had to hand that back when I left that company, I bought a 56 plate 3.0 V6 SRI and also found that the illuminated vanity mirrors, rear dome light and sunglasses holder wasn't there. I was shocked to find that the wiring wasn't there but a mix of eBay and a morning in a scrap yard or two sorted that lot and gave me an auto dimming mirror and rain sensor too!
    On the low washer fluid, check your washer bottle to see if it has the sensor in the side, if not if the plug is there it is easy to fit one. If it is there or you do fit one then it should just be a few minutes to program in; get yourself off to the scrap yard and get an auto dimming interior mirror and cover, fit those and then get the fluid warning and mirrir activated at the same time.
    I changed my CD30 for a CDC40 recently, much better than the CD30. Highly recommended.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Seems to be every October in the Vec C's production Vx have removed/changed something.
    Oct '02 - We can assume just now the kerb light and lockable glove compartment have been removed. If not these something subtle.
    Oct '03 - Possibly more wiring removed. Is this not the introduction of the 3.0CDTI's?
    Oct '04 - One of the bigger, Veccy and Siggy become full canbus. Boot and door lock buttons disappear from passenger door. Ability for working TC button reduced - practically - to zero. SRI's loose the chrome window trim, rain sensing wipers and auto dimming mirror.
    Oct '05 - The big one - Facelift. More wiring also removal rear vents if not the year before. SRI's get the chrome window trim back.
    Oct '06-End of production - More wiring removed.
    Gazza4
    Oct 2010
    Lincoln
    Well I've got the rear interior light sorted but only by soldering from the front light and cutting the hole in the roof at the back
    Chelmsford
    I love my 04 plate... All the toys still in place...
  1. How tight are you?
    By signum_rob in forum General Chat
    Last Post: 14th May 2012, 21:48
  2. Tight Van Man
    By Big Dave in forum General Chat
    Last Post: 16th June 2011, 11:07
  3. Replies: 15
    Last Post: 2nd August 2009, 00:11
  4. hee hee im a tight wad!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2006, 21:57
  5. Tight Skirt............
    By Ride-On! in forum Comedy & Humour
    Last Post: 5th August 2006, 20:38
