Results 1 to 10 of 13
Thread: No Washers Front Or Rear!
    Regular Member MRLUBBERLUBBER's Avatar
    North Lincs
    Default No Washers Front Or Rear!
    Got my heating sorted and now the washers don’t work front or rear! Checked the fuse and it seems ok. What’s the best/worst case scenario here anyone any ideas? When I go to push the stalk control for the washers no noise at all, the wipers work fine though. Thanks.
    Dec 2010
    LEEDS
    maybe the washer pump itself packed in then
    North Lincs
    Expensive do you think?
    North Lincs
    Presume there's one pump that works the front and rear washers then or not?
    Dec 2010
    LEEDS
    not that much i would think
    not that technical minded but im sure seen threads on here saying you can even get the pumps from halfrauds for bout 15 quid or so and easy enough to change
    North Lincs
    Cheers Gazleeds!
    Regular Member Dazzy2006's Avatar
    Notts
    You can pick up a pump from ebay for the grand total of £6.50
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Have you checked to see if the washer pump filter is clear ?
    These can clogg up and congeal,pull the passenger arch liner back and pull the washer pump out,and then take the pump filter out and give it a rinse under warm water or put it in a cup of boiling hot soapy water and leave it to soak for 10 minutes.
    13 Post(s)
    Quote Originally Posted by Aikon58 View Post
    Also remember to give the wash bottle a good rinse out too - otherwise the filter will just clog up again.
    13 Post(s)
    Quote Originally Posted by MRLUBBERLUBBER View Post
    Yes, one motor. The electrical polarity is reversed when you want to squirt the rear screen. Basically it spins the motor in the other direction.
  1. front washers
    By coooky in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2012, 17:28
  2. Bulb Failures & Front Washers Not Working
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2010, 21:04
  3. Front washers
    By Nicolas in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2010, 19:05
  4. Windscreen/rear screen washers kaput!
    By diesel dog in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2009, 09:37
  5. Front washers trickling!
    By Jamie in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 18:08
