Thread: Oil filter spanner.l
    Jun 2009
    Middlesex
    Default Oil filter spanner.l
    I need to do an oil & filter change on my vectra 2.2 direct elite.(Z22YH)Is there a special spanner/socket tool reqired to remove the top of filter bowl.I have not done this job on this car before,are there any handy tips i could be given to aid doing this job.
    Many thanks Dobs
    north east
    dont quote me on it but i think its a 32 mm socket / spanner.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If you use mole grips make sure you protect the plastic with a thick cloth, but as Ros said I'm sure its 32mm.
    Jun 2009
    Middlesex
    Many thanks,I will try 32mm spanner/socket.Hopefully try to do it over weekend.
    Dobs
    Regular Member Keif's Avatar
    In the Garage
    32mm socket and a long extension. Job done!
    Feb 2007
    North west
    I take it its a cartridge filter ? doing mine this weekend hopefully. Got a new sump plug and washer just in case. Also a filter housing seal. Anything else i need to know ? Ive never done an oil filter in a housing before, just screw on filters.
    In the Garage
    Removal is easy, it may just be a little tight. Remove the large rubber O-Ring
    Fitting, make sure the cap and housing is as clean as possible from old oil.
    When you've fitted the new O-Ring, smear some new oil around it to ensure a good seal.
    Ensure the new filter is clipped correctly into place.
    Tighten the cap, but not over tight.
    Nothing difficult really.
    *Just a note, some caps have a 1/2" square in the centre to fit a ratchet/extension in. DON'T use it. You'll more likely damage the cap. Using the 32mm socket is the way to go.*
  1. water in diesel filter, spanner light and fault code
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2011, 19:24
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. spanner lindicating water n fuel filter
    By bobk1 in forum Engine & Drivetrain
    Last Post: 1st September 2009, 20:49
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
vauxhall oil filter cap socket z22yh
