Results 1 to 10 of 23
Thread: Have i made a mistake CDTI!!
    prestatyn
    Default Have i made a mistake CDTI!!
    Hi all mentioned i was looking to part ex my saab for an 07 vectra sri cdti 150 auto,got it yesterday and im over the moon,BUT tonight sitting in the drive through i reved the engine and theres an whining noise which speeds up with the engine,having a look on this site im lead to belive its the tensioner of the alternator belt,but the more worrying thing was i could smell oil burning,and when reving it slightly the revs took there time to come down,checked the oil on the dipstick and its show half way but its not very thick on the dip stick lucky i have 3mths warranty,but any ideas before i go back to the garage tomorrow would be highly appreciated
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    To me there is only one cause - Turbocharger is on it's way. The whining is the bearings and the oil smell coupled with the 'runaway' revving (engine will rev on it's own or will take time for revs to drop when throttle is released when in neutral/clutch depressed). At least get it looked at as it could fail at anytime and the engine will run on the oil and could possibly self destruct.
    Gaza4
    prestatyn
    do you mean the turbo bearings
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by robsriturbo View Post
    Yip that's what I said m8, But I say get them checked.
    Gazza4
    prestatyn
    had it 2 days hope the garage stand up to there warranty what sort of job is it to do,im thinking all sorts now
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    If you paid for it in the last 7 days you shouldn't have a problem. You also have the right to reject a car within 7 days if the seller refuses to fix the fault so I believe. Phone CAB m8 if you're in doubt.
    Gazza4
    prestatyn
    really hope this gets sorted as i love this car,once turbo replaced is all fine then cheers for your advice mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    If it is the turbo m8, you were unlucky as the turbo isn't a common fault on these.
    Gazza4
    prestatyn
    is there a way to check before i go to the garage as it would put my mind at rest knowing as i know they will have it for a few days dont know what i will do for car just my luck lol
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Exclamation Get Proper Advice before you do this
    There is, however I ain't 100%.
    Follow the intake pipe coming from the top of the airbox - you will come to the MAF sensor with it's electrical connection, keep following the pipe and after the MAF there is a soft rubber part of the pipe for flex, this is attached to a solid plastic pipe by a jubilee clip. This solid plastic goes down and attaches to the tubo compressor.
    If you remove this pipe (God only knows how but it is possible, other members have done it apparently) and push the compressor wheel gently it will move along its axis and you can gently pull it back but not by much.
    There should be little movement, but not much. Excessive movement means the bearings are going or are shot. There will be oil there anyway regardless of failed bearing or not as the crank case breather vents to the intake system before the compressor wheel.
    Remember and only do this when the engine has been off and cold - that compressor gets very hot with the oil vent and charge.
    I would stick up another thread m8 asking for the details before doing this, as someone may be able to guide you alot better.
    Gazza4
  1. Woops, ASDA have made a mistake
    By m8internet in forum General Chat
    Last Post: 19th March 2011, 03:31
  2. I feel i have made a big mistake
    By corderz in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2011, 23:54
  3. Morning...made a mistake with my EGR Valve
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2009, 21:10
  4. Have I made a mistake? Please tell me what you think !
    By S14RRJ in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2008, 16:56
  5. Have I made one big mistake?
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2007, 17:56
