Results 1 to 3 of 3
Thread: Signum intermittent starting problem
    N. Ireland
    Smile Signum intermittent starting problem
    Hi all. My 2004 Signum 1.9CDTI has recently started giving random problems starting from time to time. I have noticed on the dashboard display after turning the key to position 2 if the engine management light comes on and I can hear the intank fuel pump running it will allow the engine to start OK. The times that the engine management light doesnt come on, there is never any sound from the fuel pump and the starter motor will not turn over. A yellow hazzard/skid triangle illuminates. Usually, after switching the ignition on and off a few times the fault will eventually clear and the fuel pump can be heard running before the starter will turn the engine over. I was wondering if the in-tank fuel pump tends to give trouble in these models or am i completely looking up the wrong avenue! Any help is greatly appreciated. cheers
    Nov 2010
    Maidstone
    Im no expert but that sounds like the characteristics of immobiliser problems...
    N. Ireland
    Hi, Thanks for that. Do you know of any fault diagnosis equipment I can purchase that would put me in the right direction?
  1. Intermittent starting problem?!?
    By TAB in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2012, 23:49
  2. Signum 2.0 dti starting problem
    By portreathbeach in forum Engine & Drivetrain
    Last Post: 4th February 2012, 16:05
  3. 2.2 dti intermittent starting/low down problem
    By cybergen in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 18:07
  4. 1.9 cdti intermittent starting problem (air leak?)
    By moff747 in forum Engine & Drivetrain
    Last Post: 16th April 2011, 15:54
  5. Signum starting and running problem
    By DanC in forum Engine & Drivetrain
    Last Post: 24th February 2010, 12:58
