Results 1 to 10 of 15
Thread: code reader
    Sep 2009
    Glasgow
    Default code reader
    purchased this one, as others on here have bought it. http://cgi.ebay.co.uk/Diagnostic-Sca...item45f2cd9c7a
    Now i have an error on startup with the spanner light that goes out after a few mins, but this reader dosn't detect any codes, but will allow me to reset the light, my grandads dawoo matiz also has an error but again reader shows no codes and wont reset light, my wifes astyra 1.7 cdti has been sitting a few days and when she drove off out this afternoon, the spanner light came on along with what i think is the battery light, plugged in reader and no codes found ? and wont reset the codes, is this normal or do i have a faulty code reader.
    Regular Member djr69uk's Avatar
    Midlands
    if it goes out after a few mins/miles then it's almost certainly a glow plug chap. 99% sure. i have the exact same reader and it didn't pick up on my glow plug fault either. if u can find someone nearby with opcom/vauxcom they can confirm... or you can extract and test the plugs yourself.
    Sep 2009
    Glasgow
    have you managed to get any codes with your reader..
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I've just got one of these. Heard rumours they have trouble reading the 2.2 DTi. I've got a Vec (52) 2.2 DTi SRi and it reads them fine, although might talke two tries. On my other car - a 1.9 CDTi SRi 150 Vec (56), it reads first time every time
    1 - Plug in code reader.
    2 - Put key in ignition then turn on ignition. Do not start engine.
    3 - Wait 30 seconds, then press "enter" on the code reader.
    4 - It should stop when it shows "CAN" then read teh codes.
    It only shows "live" codes when the EML light is on. I've tried this by disconnecting the MAF and it detects it fine.
    It won't show "old" codes - if you disconnect and reconnect the MAF, no codes are shown.
    Sep 2009
    Glasgow
    it wont show any codes that are stored thats what i thouht it did, what tools do i need to see stored faults, in a handheld unit
    Jan 2010
    glasgow
    if you want to know the codes on you vec mate and your stuck i can read them for ya i also have a elm scanner tool to so could do the dawoo if its there to if thats any help to ya bud
    Sep 2009
    Glasgow
    what u using mate, why wont my reader show codes.
    Jan 2010
    glasgow
    some code readers only show some codes depending on its spec and what the codes are the code reader im using we are not sup to talk about on here mate i also have a elm 327 code reader did you unplug your maff run the car for 5-10 mins switch it off plug your code reader in and turn the key to on dont start it and turn on the code reader and see if it shows the maff fault if not you may have a faulty code reader
    Sep 2009
    Glasgow
    will this error go after i plug inmaf again, will it cause any probs, will be looking at getting a cheap laptop and the code reader thats we are not supposed to talk about.
    Midlands
    Quote Originally Posted by nokiaman1978 View Post
    Yes, it does pick up other codes from engine management etc... it told me I had the dreaded P1109 swirl actuator issue
    It does pick up historical faults. If a fault is live then it presents them with a -P, otherwise it is a stored fault but not live.
    Hope that helps.
  1. Code reader
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2012, 22:05
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. Code Reader
    By Paddy in forum Engine & Drivetrain
    Last Post: 4th April 2011, 21:21
  4. Code reader
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 18:21
  5. code reader
    By stevie in forum Engine & Drivetrain
    Last Post: 11th April 2008, 20:48
elm 27 wont talk to vectra c 2.2dti
