Thread: disc size
    Nov 2009
    nottinghamshire
    Default disc size
    I was wondering if anyone on here knows the standard disc size on the front wheels for my 150 diesel sri. They have warped due to heavy braking and i want to replace them so need to know the size and also could you recommend any aftermarket ones to use. i thought about buying some grooved or cross drilled ones any views on this? any comments appreciated
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    285mm front 278mm rear
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Regular Member Jezzy's Avatar
    S.E
    Jul 2006
    Northampton
    Trim : Sri
    Nice. this needs to be made sticky
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's actually in the part numbers section
    Nov 2009
    nottinghamshire
    confused
    cheers for the replies, does anyone have any views on the grooved or cross drilled discs has i have never used these before and would like a bit more bite from the brakes and try to stop brake fade
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Personally I wouldn't touch drilled discs as the holes can crack with the temp changes. Grooves would be ok though, just remember they may make a slight rumbling sound when slowing down
  1. Brake Disc Size
    By hodge725 in forum Suspension, Wheels & Brakes
    Last Post: 2nd November 2012, 17:41
  2. what size disc do i need
    By Grimo72 in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2010, 17:47
  3. Confused about disc size
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2010, 21:16
  4. Brake Disc Size...
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2008, 21:22
  5. disc size
    By wingers1982 in forum Handling & Braking
    Last Post: 14th February 2008, 23:57
