Results 1 to 10 of 22
Thread: Fault codes p0500 and p1222?
    Apr 2008
    Merseyside
    Vehicle : Vauxhall Vectra
    Engine : 1.9 cdti
    Default Fault codes p0500 and p1222?
    i have a 53 plate vectra diesel and i started it up this morning, it fired up then cut out straight away, I then tried again but it wouldnt start it was like it had no fuel. I tried again and got it going and gave it a big rev and loads o white smoke came out but it stayed running. Iv just gone out to start it and it trys and trys but it doesnt fire. I have a cheap fault code reader and it gave me them 2 codes. Any help would be appreciated.
    Mike
    Northampton
    Engine : A20DTH
    Mileage : 88000
    This site should help you with the codes http://www.topbuzz.co.uk/info/fault_...ault_codes.htm
    a quick google and it may not be good news as the code p1222 refers to the fuel pump which is very expensive.
    Apr 2008
    Merseyside
    Engine : 1.9 cdti
    Iv had a look under the rocker cover and haven noticed these pipes have bad splits in them, would they have an effect on it not starting?
    http://img46.imageshack.us/img46/2713/12359119.png
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by vectra2004 View Post
    Well I would replace them regardless, which engine do you have? 2.o DTi?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No wonder it's not starting, those are the leak off pipes, there is air getting into the system and stopping diesel being pulled through. Get them sorted first (hopefully it should sort the problem)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I thought thats what the pipes were but was waiting on confermation of his engine. Replacing these should solve your starting issue as its a common problem. Make sure you replace all the pipes not just the split ones
    Apr 2008
    Merseyside
    Engine : 1.9 cdti
    ok, but what about the braiding on the pipes do i get that from vauxhalls? Cheers
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by merikiito View Post
    It's a 2.0 dti, also remember to change all t-pieces as they can split too
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would imagine you can get a full kit from VX, pipes, T-pieces all in
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Leakoff pipe 1x 93181131
    T pieces - 3x 9281478
    And here's the How 2
    http://www.vectra-c.com/forum/showthread.php?t=105308
  1. Fault codes - what are they?
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2017, 22:09
  2. Fault Codes
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2012, 18:48
  3. fault codes
    By bigcarp1953 in forum Engine & Drivetrain
    Last Post: 13th December 2010, 15:04
  4. Fault codes ?
    By papz in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd October 2009, 20:53
p1222 opel
p1222 opel vectra c
p0500 vectra c
p1222 vectra c
p0500 opel vectra c
Opel DTC P1222-FA
p1222 vauxhall
getting p1222 fault code vectra
p1222 opel zafira
vauxhall p1222
opel vectra c p0500
P0500 vectra c 2004
p1222 opel vectrap1222 opel fault codeopel vectra c 2.2 y22dtr p1222-fap1222a opelp1222 problema opelopel p1222-fap1222 opel zafira 2.2 dtiOpel zafira 2.0 dti fault p1222opel p1222 fagreska p1222 kod opel vektre cholden vectra p 0500p1222 fault code opelP0500 vauxhall signum
