Thanks Thanks:  1
Likes Likes:  3
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 72
Thread: Why doesn't my Vectra 1.9 CDTi warm up ANSWER (mods can this be made a sticky??)
  1. #41
    Nov 2011
    devon
    Vehicle : vectra 1.9 cdti
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    well my question is at what temperature should it be reading.my 120 takes a good few miles for it to move the gauge but i have spoken to a local guy who said i shouldnt always believe the gauge,the sensor can be faulty?
    mine from memory dont sit near 90 but i aint having any problems starting yet(touch wood) and its now running better than ever having cleaned the egr up properly,so only want to do this if it will make a genuine difference .
  2. #42
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The gauge does not start from zero but 70 so thats why it takes a while to move, depending on the speed you are doing it can take 10-20 mins to warm up. It should then sit at roughly 85, once warmed up it should not budge. If it drops down while driving it is faulty. If it goes up when stationary and then drops down below 85 when moving its faulty
  3. #43
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    Thanks for that.i will keep an eye on it ,but pretty sure it's gonna need doing but as I will be needing the Cambelt and water pump in the near future and a remap if I can afford it,I am not gonna worry too much.the heaters work well etc,so I ain't gona freeze just yet.
    i assume getting hotter quicker will also help the car if you do a lot of local running about ,so will maybe help prolong the life of some components if they are running properly?
  4. #44
    Nov 2012
    Goole
    Quote Originally Posted by Mads View Post
    is this the right clicr tool for the hoses?
    http://www.ebay.co.uk/itm/3903665157...ht_1599wt_1270
    Anyone know if this is the right tool for the clips on hoses when changing the stat?
  5. #45
    Administrator plasma's Avatar
    On the Forum
    574 Post(s)
    Engine : 150
    Mileage : 74000
    dont think it uses them it uses a spring type clip which exerts tension on it.. lemme find a link that tools where uses clips which are normally found on the oil breather lines and possibly vac lines
    http://www.ebay.co.uk/itm/LONG-REACH...item257777d025
    theres is a cheapo kit on ebay somewhere with 8 different types, i find sometime when you refit this spring clips they dont exert the same amount of tension as before and causes the pipe to leak, happened twice now on different cars i've dont the stat on and changed it to a jubilee clip
    these are the spring clip types for the stat as far as i can remember
    http://www.google.co.uk/imgres?start...59&tx=35&ty=44
    this is the set i bought in the end
    http://www.ebay.co.uk/itm/New-Profes...item2ebe04e316
  6. #46
    Dec 2012
    bradford
    Change my thermostat today on 120 bhp 1.9cdti. I had to cut the bracket with a dremel multi tool 29.99 from b and q. 45 for thermostat. Better than vauxhall 380 to change a thermostat.
    All thanks ti this site. Classic
  7. #47
    Regular Member Albert99's Avatar
    Nov 2012
    Glasgow
    I've just done the thermostat on my Signum (1.9 CDTI 150) with help from the fine guides and info on here. Bit fiddly but not too bad and well well worth it! Temp needle was all over the shop (mainly just over 70 on the move) now its 86 degrees all day long.
    Thanks a million
  8. #48
    Jan 2013
    Hartlepool
    My temp gauge does not move from 70, but I still get warm air from the blowers, could it be a sensor rather than the thermostat?
  9. #49
    May 2013
    Derby
    Trim : SRI
    Engine : 1.9
    i changed mine, got from eurocarparts. still same problem. what shall i do ?
    ta
  10. #50
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Did you bleed the system?
  1. V6 CDTi problems and cures ?sticky?
    By hebblemarine in forum Y & Z30DT Specific
    Last Post: 15th January 2012, 10:39
  2. Vectra C 3.0 V6 CDTi warm up time???
    By actionman in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:38
  3. Very slow warm up - 150 CDTi
    By RobW in forum Engine & Drivetrain
    Last Post: 5th January 2008, 13:55
  4. Home made Opel mods
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2006, 22:13
  5. 3.0 CDTi Warm up times
    By dieselvec1 in forum Engine & Drivetrain
    Last Post: 11th October 2005, 10:31
vectra c not warming up
why heating slow on vectra
https:www.vectra-c.comforumshowthread.php126311-Why-doesn-t-my-Vectra-1-9-CDTi-warm-up-ANSWER-(mods-can-this-be-made-a-sticky-)page5
why does my vetra heat up to or slightly over 90
why cdti engine slow warming
1.9 cdti 150 takes ages to warm ukp
Vectra c engine winter block heater
how to fast get hot 1.9 cdti engine
vecta cdti never warms up
vectra c not boasting when warm
vectra 1.9 cdti not heating
vectra 1.9 cdti heat goes up
engine needs warming up vectra
my vectra doesnt warm up properly
winter thermostat for vectra 1.9cdti
vectra warmup
z19dt not warming up
vectra c not warmimg up
