Thanks Thanks:  1
Likes Likes:  3
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: Why doesn't my Vectra 1.9 CDTi warm up ANSWER (mods can this be made a sticky??)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Why doesn't my Vectra 1.9 CDTi warm up ANSWER (mods can this be made a sticky??)
    for info:
    If you have problems with your Vectra C 1.9 CDTi running cold in the winter and other times then you may have a thermostat issue.
    There are two orginal thermostats fitted which both look the same, 55487784 and 55187784.
    Both these part numbers have been superseeded with 55203388
    The new part will allow your engine to warm up and stay roughly at 80-85 degrees and finally you will get really hot air from your heater which I never had from when I first got the car.
    Finally do not follow the Haynes guide. There is no need to drain your system unless you want to reuse the coolant (it will take approx 2.5 litres to refill done my way) or remove the battery cover and battery. Make sure you do this when the engine is cold!
    The Thermostat is supplied as a complete unit with its housing and Temperture Sender (it should cost around £40 plus antifreeze and a small Jubilee Clip from the dealer).
    You can find the housing on the right hand side of the Engine block nearly opposite the glow plug relay which is at the side of the battery compartment (looking at the engine bay from the front of the car).
    You will need to move the Glow plug relay to one side to make things a bit easier. Then remove the intercooler pipe and all the pipes connected to the Thermostat housing including the wiring to the Temperature sender. It is held in by 2 x 13mm bolts.
    There is also a nut which is holding a couple of pipes to the housing which also needs to be removed and the pipes pushed out of the way so you can get the thermostat housing out. Under no circumstances drop any of the bolts or nut otherwise you will have to get under the car and drop the flap on the plastic undertray/sump guard which is not easy when you are working on the drive .
    Clean the area around the engine block with a scouring pad before refitting the new housing. The rubber gasket is built into the new housing so there is no need to use any sealant. I think you need to torque the bolts done to 20Nm but I need to check.
    The above info has been put together will information gained from other members on the forum plus I had the same issue and this what I did to resolve it.
    Please beware that many Vauxhall Dealers will claim that there is no issue whatsoever and are totally unaware of the new part.
    Before this was done my car on a really cold day would not warm up unless I was stuck in traffic. The Temperature Gauge would hardly move for most of my journey now it gets to 80-85 degrees and stays put.
    Mods can this be made a sticky as the question regarding 1.9CDTi's running cold is always being asked on the forum.
  2. Likes artvec liked this post
  3. #2
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Great write up Lee would this not be best put in how2 section ?
    Irmscher Insignia CDTI 130
  4. #3
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by bigmac View Post
    Possibley in both
  5. #4
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Thumbs up Feedback
    my thermostat had gone on my elite 54 plate 1.9 cdti.
    I purchased the new superceded thermostat & it works like a dream, heater a lot more hotter & car's performance has returned as well due to engine running better.
    Thanks lee
  6. #5
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default How to tell the difference between old and new thermostats
    If you look through the aperture you will notice that the new thermostat is much stubbier whereas the old one is nearly as long as the aperture.
    I forgot to take some pictures when I removed mine, can someone post some picture up when they does theirs?
  7. #6
    Administrator plasma's Avatar
    On the Forum
    556 Post(s)
    Engine : 150
    Mileage : 74000
    Mines due in next cpl of week Lee... Actually have the thermostat in the garage, will try to dig it out lol
  8. #7
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    my thermostat was gauge was going up n down like a yoyo put a new thermostat in 2day and is working like a treat dosent take ages heating up anymore !!!
  9. #8
    Regular Member djr69uk's Avatar
    Midlands
    done mine on my 150 today. the thermostat was clearly goosed! it was open (cold) whilst the new one was closed. been for a blast the the temp is around 85-90 constantly even with heater on full pelt! i know people have done write up on ways to do this, but not seen piccies, so i've taken some and hopefully it can form the basis of a 'how2'.
  10. #9
    West
    how much was the new stat?
  11. #10
    Dec 2010
    belfast
    i got mine on ebay for £11, if that helps!!!
  1. V6 CDTi problems and cures ?sticky?
    By hebblemarine in forum Y & Z30DT Specific
    Last Post: 15th January 2012, 10:39
  2. Vectra C 3.0 V6 CDTi warm up time???
    By actionman in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:38
  3. Very slow warm up - 150 CDTi
    By RobW in forum Engine & Drivetrain
    Last Post: 5th January 2008, 13:55
  4. Home made Opel mods
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2006, 22:13
  5. 3.0 CDTi Warm up times
    By dieselvec1 in forum Engine & Drivetrain
    Last Post: 11th October 2005, 10:31
vectra c not warming up
why heating slow on vectra
1.9 cdti 150 takes ages to warm ukp
Vectra c engine winter block heater
how to fast get hot 1.9 cdti engine
vectra c not boasting when warm
vectra 1.9 cdti not heating
vectra c not warmimg up
engine needs warming up vectra
my vectra doesnt warm up properly
winter thermostat for vectra 1.9cdti
vectra warmup
z19dt not warming up
why does my vetra heat up to or slightly over 90
vectra 1.9 cdti heat goes up
vecta cdti never warms up
why cdti engine slow warming
