Results 1 to 10 of 11
Thread: Weird noise from Right Rear wheel
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Weird noise from Right Rear wheel
    Hiya guys. long time no see.
    I have a grinding/rumbling noise light braking on the right rear wheel but its not constant, happens now and then.
    Any ideas what it may be as disc/pad wear is the same on front and rear wheels, but only right rear is making the noise.
    If it helps, it never makes the noise braking in reverse.
    Any help greatly appreciated.
    Russ
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'd think possibly bearings but then again it would probably happen all the time if that was the case. I'm a bit stumped on that one!
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by cont1204 View Post
    Its driving me nuts! Might take the wheel off at work and investigate.
    Mar 2007
    Grimsby, Lincs.
    While im in there i want to measure my discs and pads. is there any limits i should be aware of whilst measuring.
    Got another MOT in April.
    Central Scotland
    Good chance its wear on the caliper carrier as disc turns it picks up the pad then drops it as the carrier is made of alloy they wear giving you this weird noise. Jack the car up handbrake off spin wheel an watch outer pad to see if it goes up and down with a high spot on disc The noise you hear is the pad falling back down on to the carrier, The part to watch on the pad is the little locating lugs in the carrier, Hope this helps. P/S The niose this can create is like a slack prop shaft rumble on a rear wheel car.
    £36 from Vauxhall plus vat
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by Jim.c View Post
    Wouldnt that be consistant though? im getting this grinding/rumbling every 3 or 4 braking cycles.
    Central Scotland
    I had no noise when reversing as the pad was down on the other end of the carrier simple way to check is when it starts to make the noise again gently put your left foot on the brake make shure no one is behind you, if the noise goes away under gentle brake pressure that is probably the cause, reason i am saying this is i have just had a similar problem and the fix for me was a new alloy carrier.
    Mar 2007
    Grimsby, Lincs.
    cool. ill check it out
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    think you will find the inner pads are down to metal did some last week for a friend 57 plate sri with 31k on....
    durham
    Trim : Leather
    I had a simmilar issue mate it's a grating grinding sort of noise, on mine it was the rear callipers partly seized and not letting the pad back off from the disc. Hth
  1. Rubbing noise from rear wheel
    By Mike RB in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2012, 19:03
  2. Tapping Noise from Rear N/S Wheel?
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2010, 20:04
  3. rear wheel movement and noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 5th August 2008, 12:37
  4. Weird Wheel Noise?
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2007, 01:21
  5. thud noise from rear wheel
    By al100 in forum Suspension, Wheels & Brakes
    Last Post: 11th December 2006, 11:25
