Results 1 to 10 of 15
Thread: service light
    wolverhampton
    Default service light
    Hi all,
    does anybody know how to re-set the service light ?
    On previous Vx's you could do this with a combination of holding down (I think) the trip reset button and turning on the ignition - or something along those lines.
    I don't think you can do this on the C/Signum this way - only via Tech 2 (I think). I'm sure someone will be along to give a more confident reply!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You can reset the service interval countdown by pressing and holding the mileage trip, turning on the ignition (the dash lights come) and continue holding for about 30 seconds. the mileage counter will reset to 21,000 miles.
    SOUTH SHIELDS
    Correct Ste Just Had Mine Done At Local Garage Thats What He Did To Reset It
    Wolverhampton
    Here's the exact VX procedure from their manual...
    Resetting the flexible service interval (ECOService Flex) with TECH 2
    The display for the flexible service interval (time and kilometres) can be reset via the instrument assembly. The engine control unit communicates with the instrument assembly.
    Manual resetting
    Ignition OFF. The tachometer display must indicate the trip odometer reading.
    Press and hold down reset button (trip odometer button)
    Switch ignition ON and wait until the service interval display changes and keep the reset button held down for at least 3 seconds.
    After 3 seconds, the tachometer display indicates the symbol with the maximum mileage, 34.000 km for petrol engine or 50.000 km for diesel engine.
    The time counter in the instrument assembly is set to 24 months. The engine control unit receives a signal via the CAN bus and the "oil condition" is set to 100 %. The engine control unit and the instrument assembly are now reset.
    The only snag with this is that it does not reset the oil life indicator which can trip the service light. I see you have a 2003 car, do you need to reset it because of a service or does it keep coming on, some 2003 cars hav a problem with the instrument cluster, I had mine replaced under warranty because the service light kept coming on ??
    HTH
    T.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes it does. Well it did on mine when i reset it 10,000 miles ago. It has not come back on and the trip distance is now 11,000 miles.
    Others could be different, but i would not have thought so.
    It resets the mileage, I know as I have done it many times, what I said is it does not reset the oil life indicator, which means it can be tripped again before the mileage is up, as the service indicator is not controlled by mileage alone, it is driving style as well, and oil quality . Resetting via the dash board resets certain parameters but is not fool proof, as I found out .
    Wolverhampton
    Hi,
    Thanks for the info.
    I service my own Vectra that's why I ended up resetting the light myself the system is all working OK.
    Last time was last Feb i've covered about 9000 miles since then and the indicator is showing 11000 'til next service. I guess you're saying that I could get a service reminder come up based on oil life?
    The VX manual does clearly say that the procedure i've described also resets oil condition to 100% so I sort of disagree on that point, but I could be wrong. Anyway time will tell I guess.
    Regular Member denzo's Avatar
    Runcorn
    I agree with Angel Chops ... most of the Vx dealers just do the manual reset rather than a Tech2 reset, I was under the impression that the manual operation reset the oil life to 100%
  1. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  2. service light
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2009, 21:01
  3. Oil Service Light
    By welshy in forum Engine & Drivetrain
    Last Post: 24th October 2008, 11:42
  4. service light
    By jaff in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 11:02
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
how to reset service interval timer on vectra c
