Thread: Instrument cluster going mental
    Regular Member colinstar's Avatar
    loch lomond
    Default Instrument cluster going mental
    Hi there sorry to post a problem on my first post
    i can not seem to remember my usernam since my last problem in 2009
    well here goes
    1 have 2.2 Vectra Elegance Auto
    Ok, the first light that flashed on was the TC light (skid light i call it lol), only momentarily
    Second was the spanner warning sign which flashed on several times, then said the dials went mental turned off completley no fuel dial temp rev or speed.
    my on board cumputer the fuel distance and temp outside just had a --- in it
    Then Battery light came on then they all popped back on one after the other and just the TC light remained on . I turned off ignition turned enginge back on and all is fine
    can i maybe put this down to the adverse weather we have been getting or a glitch
    Many thanks in advance
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like the good old CIM or ABS fault mate. First off find the abs unit, its up near the passenger side strut top. Take the plug off and give it a clean with some wd40 and see how that goes.
    loch lomond
    cool i shall go do that just now many thanks
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    This one mate.
    Pull the bit circled and the plug will lift off. It could also be a dirty connection where the fuse plugs in, off the top of my head I cant remember but its in the dash when you open the passenger door.
    Unfortunately, I both of these fail, then it could be the CIM, and that's a £400 dealer fix only as it need programing.
    How old is your car, around 53 plate at a guess?
    loch lomond
    Yeah Bud 02 plate
    do you think its time to get rid before rot sets in? lol
    South West
    Have a read of this post mate:
    http://www.vectra-c.com/forum/showthread.php?t=116148
    Once you have done the ABS, and the problem still occurs, try the suggestion in the last post in the above thread.
    Rgds
    Aidi
    loch lomond
    Cool thanks for everyones Help
    too car out for a hour after spraying the plugs under the bonnet
    seems fine now (touch wood )
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Aidi View Post
    Rgds
    Aidi
    Thanks to Kman247 for taking the time to chat with me on this, i hope this might help others too in the future. Its dead simple to do and could save you a bucket of cash
    Rgds
    Aidi
    Nice, I'll keep that one in mind
    Quote Originally Posted by colinstar View Post
    Yeah Bud 02 plate
    Not really mate, it was just a common fault on cars of our year. Mine did it year's ago and hasn't given me any trouble since.
    South West
    With the amount of times this comes up, Ill put together a How2 of these two most common tips and see if it can be put with the others.
    Easy to find then for others with a similar problem.
    Rgds
    Aidi
    loch lomond
    we buy any car offered me a quick £840 lol
    if it happens again it might be time to sat cheerio
  1. instrument cluster
    By waky in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 00:31
  2. instrument cluster
    By veccyv6 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2011, 19:03
  3. Instrument cluster
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2008, 18:43
  4. Instrument cluster
    Last Post: 12th October 2008, 20:02
  5. Pinout for Instrument cluster
    By Darren in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2008, 18:53
