Thread: The Dredded Z22YH Fuel Pump
    durham
    Default The Dredded Z22YH Fuel Pump
    Yes It happend to me.
    Fuel pressure problems.
    I connected my laptop the the car using an opcom OBDII reader (bought on eBay )
    Monitored the fuel pressure and sure enough the pressure droped.
    So £300 later I fitted a new pump and now working again.
    I noticed the oil seal had "blown" from it's seat leaking hydrolic fluid into the cam housing.
    I dissasembled the pump and found it servicable.
    The seal is easy to refit using a large socket as a drift.
    I need to re fill the hydrolic fluid but the original filling port is sealed with a ball bearing, so I will need to drill a new filler hole.
    For those interested I am documenting the project here.
    http://www.somethingornothing.com/z22yh_fuel_pump.htm
    13 Post(s)
    Quote Originally Posted by 10cls View Post
    You can knock it out according to the how2
    http://www.vectra-c.com/forum/showthread.php?t=118396
    durham
    Default Z22YH fuel pump
    I am not a full member yet and could not find any pictures.
    My fault was the main oil seal blown off.
    Thanks for the link very informative.
    Luton
    Default Signum 2.2 High Pressure Fuel Pump
    Good stuff 10CLS.
    If you search under `omega2498' (me) you will see that `my' thread has had 17,000 odd Hits. Perhaps you can put a link there to your interesting thread/pics. Why do you think the oil seal blew out ? High pressure petrol leakage around the swash plate pistons - thereby blowing the seal out ?
    When you say you looked at the pressure was that from the lift pump in the tank, or the injection rail pressure ex the HP pump ?
  1. Z22YH Fuel Pump
    By jimr1 in forum Engine & Drivetrain
    Last Post: 2nd October 2012, 23:39
  2. Z22YH High Pressure Fuel Pump
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2009, 23:01
https:www.vectra-c.comforumshowthread.php126271-The-Dredded-Z22YH-Fuel-Pump
z22yh fuel pump fluid
z22yh fuel pump
what oil in a z22yh hogh pressure fuel pump
z22yh fuel pump repair kit
z22yh pressure punp oil
z22yh pump to much fluid
z22yh high pressure fuel pump oil
