Thread: 85watt bulbs? Is this the problem??
    Derbyshire
    Question 85watt bulbs? Is this the problem??
    Hi there, recently fitted HID's to the motor, long story short, they wouldnt work, had to get cancellers, now they work!
    So fitted 85watt FULL Beam, so that i could tell the difference when they were on, as the standard bulbs were cack!
    BUT, now i have the bulb error light & the drivers side will not work ( well it does, but on and off?!)
    IS this because the CANBUS system knows there 85watt and kind of shuts it down?!!
    Any help is appreciated! thanks in advance guys.
    Full Member lizard's Avatar
    Oct 2006
    southampton
    16 Post(s)
    law is 55w maximum for front, 27w for rear. not sure about the canbus on this sorry, are thay cheap bulbs, just a thought....
    Derbyshire
    Oh is it? Well there not like super bright anyway tbh.
    So could that be the problem then you reckon, like with the being a high wattage..?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Possibly. And running higher power bulbs like that you are risking doing damage to the wiring.
    Derbyshire
    Quote Originally Posted by cont1204 View Post
    Really? ******s, think i'll be whipping them out then?
    Might sound silly, but how does it damage them?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Quote Originally Posted by Davies20 View Post
    Its the current drawn through the wiring..
    @ 85w by 12v = 7A
    @ 55w by 12v = 4.5A
    as you can see alot more... as the cable are usually only just large enough power the device and putting a larger cable in would cost more, times that by 000's of motors rolling of the production line.. £££
    Also there is the heat issue, an 85w is going to give off more heat, if you have plastic headlights, fine if your driving but standstill for a lenth of time, this may have an impact.
    Just my thoughts anyway.
    13 Post(s)
    The extra currect drawn.
    That's why the lighting circuit in your house is 1mm or 1.5 mm, but the ring main is 2.5mm and the cooker 6mm.
    Derbyshire
    oh right, cheers guys.
    Well best be taking them out. Just for piece of mind though.....
    Would this be causing my bulb out light?
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Swap them over and check.. if its still out, then check you have 12v at the bulb, just to prove you havnt damaged the wiring.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Certainly take them out, as said above, it could damage your wiring and is illegal.
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  3. Problem Fitting HID Bulbs??
    By bonneyboy in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2010, 13:02
  4. fitted my hid bulbs today,but have a problem
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2008, 23:31
  5. Bulbs? whats the problem?
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2007, 23:15
