Thread: thermostat 2.2 dti
    Aug 2010
    york
    Default thermostat 2.2 dti
    Hi all ,Trying to find a how 2 to replace a thermostat on a 2.2dti
    1. Open bonnet
    2. Disconnect battery.
    • Detach ground cable
    3. Drain coolant
    Important: Only open coolant compensation tank once engine has cooled down
    • Unscrew coolant compensation tank closure cap
    • Place collecting basin underneath.
    • Open drain bolt (arrow)
    4. Detach upper engine cover
    Important: Carefully pull upwards
    • Unscrew 3x bolt
    5. Detach connection hose (1)
    • From turbocharger to charge air pipe
    • Release clamp
    Note: Lay hose aside
    6. Disconnect upper radiator hose
    • From thermostat housing
    • Release clamp
    7. Detach preheater hose from thermostat housing to EGR valve
    • Release clamp
    8. Detach coolant hose from thermostat housing to coolant pipe
    • Release clamp
    • Unclip wiring harness
    9. Remove thermostat housing (1)
    • Unscrew 4x bolt
    East Midlands
    Quote Originally Posted by tomo610 View Post
    THIS is for a 2.0dti,but it is the same procedure on yours..
    Aug 2010
    york
    Thanx :d:d:d:d
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
