Thread: Turbo Replacement
    Jan 2008
    GLOUCESTERSHIRE
    Default Turbo Replacement
    Hi
    Had my car in at garage as i have been having problems with my turbo. Have a Vectra 2.0 DTI 2002 model. Was told that am going to need it replacing but in order to ensure they ordered the correct one they would have to first remove the turbo to get the serial number.
    They quoted me depending on which ont they required £300-500 to replace it.
    Is this about right as i have no idea when it comes to stuff like this
    James
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    find you engine on the list and theres your turbo model number...
    http://www.vauxhall-turbochargers.co...ra_Turbos.html
    don't know why he wants your serial number though, its not going to help him
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You will need a high pressure version part number 24461826 Garrett M53GD15
    Irmscher Insignia CDTI 130
    Jan 2008
    GLOUCESTERSHIRE
    Thanks guys
    Not sure wht they said the would have to remove it first. Always taken my car there as they are a good at what they do and usually very reasonable.
    Just thought id check it out first though as its first turbo problem ive had.
    James
    Jan 2008
    GLOUCESTERSHIRE
    Is a replacement a job that can be done yourself or is it usually a garage job?
    WGAF#5
    if your prepared to try if you can do it yourself Both Caveman Nige and I have retrofited larger turbo packages to cars and several other members including Duncan have removed and refitted their Turbos following repairs and rebuilds
    if you can live without yours why dont you get it overhauled .... should be cheaper in the long run
    Jan 2008
    GLOUCESTERSHIRE
    Just looking to do minimum needed, as long as it lasts next year or so then i will be getting rid of car so a replacement will do for now
    Just wondered if it is a complicated procedure?
    Jun 2009
    South Coast
    its not complicated, where is the turbo on your engine, front or back of the block? Its a fiddly job and to be honest you may start and wish you hadn't started.
    You can send your turbo away to somewhere like turbo technics (not the only place) and they will completely recondition it for you and then send it back for about £350.
    Jan 2008
    GLOUCESTERSHIRE
    Im not too sure which bit its in will have to check that out.
    I have managed to find one at breakers for £150 same one which will do the job for now
    Jan 2008
    GLOUCESTERSHIRE
    Hi Guys
    Just a quick one. Is the turbo charger listed next to my engine type Y20DTH - Garrett 24461826 definately the one i am looking for?
  1. replacement mid section on v6 turbo?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2012, 18:01
  2. Todays job: CDTI 150 Turbo replacement!
    Last Post: 25th May 2012, 20:20
  3. v6 turbo cambelt replacement,how much?
    Last Post: 14th January 2012, 22:45
  4. and so it starts - Turbo replacement -is go
    By Deztroyer in forum Petrol Engine related
    Last Post: 23rd May 2010, 18:43
  5. Replacement Exhaust for 2.0 Turbo??
    By Nidge in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 20:07
