Thread: EGR valve
    Regular Member farley2708's Avatar
    antrim n.ireland
    Default EGR valve
    hi guys & girls,a mate has given me an EGR valve from a 150 cdti,going to take mine off put his on then take mine apart & clean + lub it,have seen on other posts/threads about '2 gaskets' & blanking plates,have seen blanking plates on ebay,just no sure what is meant by the 2 gaskets thing (is it the oval 1 & the square 1?)
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    The blanking plate looks like this. You can make it if you have a steel plate. Mount it on the exhaust side of the egr with two gasget on or gasget sealer and it would be fine.
    The cdti 120 engine needs a small hole in the plate to avoid eml come on. I think the 150 also need this. Maybe someone here can tell?
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    You will need a 6mm hole in to keep the eml off unless you have a remap and get the egr disabled
    antrim n.ireland
    Default egr gasket
    cheers mate,ordered 1 of ebay last night,so when it arrives will get it drilled out then get egr changed
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
