Thread: SIGNUM windscreen roofrail trim
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    Question SIGNUM windscreen roofrail trim
    new windscreen fitted yesterday due to a crack,well all seemed ok untill i noticed today that the roofrail trim which runs the length of the car and down the windscreen isnt fitted properly,how easy are these to remove and fit again correctly yourself ? are they easily broken ? cheers steve.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Just tiger seal it down!! It will be fine.
    Apr 2009
    CO DURHAM
    Quote Originally Posted by Super T View Post
    what is tiger seal ? it sounds like a bodge up,something i wouldnt do.
    Regular Member Jezzy's Avatar
    S.E
    If you use sealant it's that much more hassle if the windscreen has to be replaced again.
    Apr 2009
    CO DURHAM
    dont want to use any sealant as it doesnt need it i just want to know if they are easy to remove yourself and refit correctly without breaking them thanks steve.
    Regular Member poves's Avatar
    lancashire
    They just clip on and off ,
    start at the bottom and work upwards , then refit in reverse.
    Apr 2009
    CO DURHAM
    Thumbs up
    Quote Originally Posted by poves View Post
    cheers 4 the reply i will give it a go at the weekend
    Nov 2009
    Lancashire
    I need my windscreen replacing and noticed these trims.
    Then I noticed they ran the length of the car!
    Do the Autoglass fitters know how to remove these without breaking them and are they responsible for them if they snap them?
    They're body coloured so not going to be a cheap replacement I 'spose.
    Would I be better off going to the Autoglass centre rather than relying on the mobile guy?
    Cheers,
    Graham.
    Regular Member eaglepva's Avatar
    Up North
    They just pull up and off then just push them back on.
  1. Signum Window Trim
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:04
  2. Signum Rear Windscreen Query
    By ps2user in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 11:34
  3. roof windscreen trim
    By garty1972 in forum Bodywork & Interior
    Last Post: 1st April 2010, 17:06
  4. Windscreen side trim ( removal )
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2009, 23:21
