Thread: Coilovers vs Springs
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Default Coilovers vs Springs
    Hi Guys,
    I want to lower my car, its currently on the SRI setup so I believe so all ill get outta eibachs is 15mm. I was thinking of doing shocks aswell so moved on to looking at coilovers and found these, http://www.venommotorsport.com/produ...ory=Suspension
    Also like the fact the ride height can be what I want it to be not where the springs decide to settle!
    Has anyone got these on a 1.8vvt? The axle weights of the coilovers don't tally up with what my car is so what effect will this have? as I cant find any coilovers with the correct axle weight unless im being blind.
    Thought you guys will know more!
    Currently sits like this
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    ive just fitted coilovers to my gsi, they were the cheaper version to the ones you were looking at but im very happy with the result! i didnt have a problem with finding ones with the correct axel weight either, also get to go super low if you want!!!! bonus!!
    Aug 2010
    York
    Quote Originally Posted by TimTay View Post
    Yeah im looking for something that lets me have what I want. I was reading through your thread looks good just fancied the ones with Koni shocks,
    My 1.8 has lower weights compared to them on the site an there doesn't seem to be any other options!
    Regular Member Rab's Avatar
    Irvine
    tbh the best vectra set up is eibach springs and B4 dampers. coilovers have the habit of ruining the vectras ride dependant on brand.
    Aug 2010
    York
    Quote Originally Posted by Rab View Post
    Yeah I have seen this but also seen the minimal drop it would give aswell so I couldn't make my mind up!
    Can anyone let me know what the ride is like with the FK's on?
    Oct 2007
    Shropshire
    The weight of the car is not as big an issue because you can adjust the ride height to get it too sit right and all are progreesively wound so it should be hard to hit the end stop.... Just get the closest and it will be fine.....
    Aug 2010
    York
    Quote Originally Posted by mucklestone View Post
    Thanks mate, just seems there is only one weight on these!
    Regular Member tappetpaul's Avatar
    Jan 2010
    dundee
    ive got the cheaper fks on mine and had them on a couple of months and think they are awsome and i bought them as i can adjust the height. the only thing with the ride is it can be quite bouncy on humpy roads but going into corners is brilliant car sticks to the road like its on rails.
    would i swap for springs and shock setup no chance!!
    Nov 2010
    BRECHIN
    Aug 2010
    York
    Cool, looks like im putting coilovers on!!
    Just sort out this axle weight issue and should be done!
    Thanks guys
  1. Springs / coilovers
    By brod999 in forum General Chat
    Last Post: 17th November 2012, 23:08
  2. coilovers or springs
    By richardcee in forum Handling & Braking
    Last Post: 12th March 2012, 21:49
  3. need advice coilovers or springs.?
    By Vectra boy in forum Handling & Braking
    Last Post: 24th July 2011, 23:48
  4. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  5. Coilovers and lowering springs?
    By bedo13 in forum Handling & Braking
    Last Post: 27th October 2010, 16:21
