Hi,just changed the lambda sensor(pre-cat 1 on manifold) because it was showing fault code p0170-1;;
now that I've changed it I'm now getting the following codes;
P0130 - O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
(01) - Not present
P0100 - Mass Or Volume Air Flow Circuit Low Input
(06) - Present
P0403 - Exhaust Gas Recirculation Circuit Low Voltage
(02) - Present
P0135 - O2 Sensor Heater Circuit Open (Bank 1 Sensor 1)
(04) - Present
P0141 - O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
(02) - Present
P0443 - Fuel Tank Ventilation Valve Voltage Low
(02) - Present
P1110 - Intake Manifold Solenoid Valve 1 Circuit Low Voltage
(02) - Present
please any help these problems guys
