Thread: Can't get boot to open
    Oct 2010
    N. Ireland
    Default Can't get boot to open
    Hi Lads,
    Cant seem to get my boot open today, just makes the buzzing noise when I push the button. I dont think its frozen as its facing the sun and should be thawed. Can anyone help?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    probably frozen the seals, if the lock is moving then that doesnt seem to be your problem. I had this once and had to give it a light tug and it opened
    Oct 2010
    N. Ireland
    Thanks for reply mate, the boot makes a buzzing noise but doesnt "click" like it should.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    i've had this push down on the boot and press the button and pull boot.
    West London
    as above, push down on the boot quite hard, then try it, failing that, do you have a keyhole on the button? could try that, failing THAT, Climb in through the back seats, take a torch, as you get to the inside where the lock/button would be, theres a circle black grommet like thing, pop it off and then theres a plastic square, use a suitable tool (i used a large flathead screwdriver wedged in) and turn, should open it that way - once its open you can work out whats going on.
    Oct 2010
    N. Ireland
    Quote Originally Posted by mattster87 View Post
    Thanks mate, got it opened like u said with the screwdriver, seems to be working ok now. Thanks for your help
  1. Boot doesn't open
    By adierolfe in forum Bodywork & Interior
    Last Post: 18th May 2018, 11:14
  2. boot want open
    By tonci26 in forum Bodywork & Interior
    Last Post: 28th December 2011, 17:23
  3. boot when open
    By slugo in forum Bodywork & Interior
    Last Post: 6th April 2011, 18:44
  4. boot will not open!!
    By p.bamforth in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2010, 13:00
  5. cant get my boot open!
    By pogo in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2008, 21:08
