View Poll Results: What should I do regarding suspension
Voters
45. You may not vote on this poll
  • Get Vauxhall to do it for £200 - £250
    0 0%
  • Source parts & get local mechanic to do it
    11 24.44%
  • Get lowering springs
    34 75.56%
Results 1 to 10 of 13
Thread: Well rear spring is broken ... what to do?
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Default Well rear spring is broken ... what to do?
    Just had the veccy in at the dealers today due to suspected ARB issues. It turned out it needs new ARB & drop links done on front for approx £110, which doesn't seem to bad.
    Anyway also they said my rear spring is broken! So what should I do, they quoted me £250 to replace or £200 non gm parts, surely I could get a decent set of lowering springs inc fitting for £200??
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    My local hi-q quoted me £191 for front spring, front pipe exhaust supplied and fitted. So for rear spring fitted would be less. They quoted me £50-70 to fit full set of lowering springs.
    But I have a bro in law with own garage so it cost me a cuppa tea lol
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I have a set of standard springs here if you need any,easy to fit yourself
    Regular Member russ1969's Avatar
    Worthing
    i have i rear pair you could have as i had a front one go last month
    As said be before easy enough to do yourself as i did them myself a lot easier to do than the fronts
    I personally would buy a set of lowered springs and replace the lot all at once
    Got a set of jamex myself and cost £110 all in delivered to my door might not be the best but do the job
    Regular Member vectraboyy's Avatar
    I paod £45 from a local motorfactors for a ne wone for mine. and it took bout 30mins to fit myself (and i was in no rush either!)
    Jul 2010
    Skipton
    Thanks for the advice so far guys
    Well from the sound of it I might as well get a set of 30 or 35mm lowering springs. This is supposed to drop a sri another 15mm from what is normally is
    Regular Member Rab's Avatar
    Irvine
    aye if you get 30mm eibachs it drops an SRI 15mm.
    even LMF are cheaper for a full set of eibachs.
    Regular Member Craig1985's Avatar
    harwich essex
    Euro car parts have 20% off at The mo online promo code- jan20
    Regular Member Keif's Avatar
    In the Garage
    No Brainer.
    Lowering springs - Better metal, will last longer, stronger and cheaper.
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    35 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Quote Originally Posted by Keif View Post
    No Brainer.
    ^^ I agree completely. I paid something like £152, delivered, when I bought my Eibach kit from LMF Vauxhall - an approved trader on here. They made a significant improvement to the handling of the car too.
    Paul
  1. Broken eibach rear spring
    By tonyblade in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 11:28
  2. MOT failure - broken rear spring
    By Hue Jarse in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 16:37
  3. broken rear spring
    By rozzer2006 in forum Suspension, Wheels & Brakes
    Last Post: 30th October 2012, 00:51
  4. broken rear spring
    By kdadidog in forum Suspension, Wheels & Brakes
    Last Post: 14th November 2009, 13:23
  5. Broken Rear Spring
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 22nd August 2009, 20:46
lmf vauxhall promo code
saab 2.8 v6 rear spring broken
