Results 1 to 10 of 11
Thread: 2.0 dti will only start once per day
    bristol
    Default 2.0 dti will only start once per day
    Hello everyone hope some one out there can help !!
    my vectra will only start once per day first thing on the button then will not start just turns over and over this is the parts i have changed.
    injectors, seals , o-rings, new glow plugs & time relay, battery, full service,leak off pipes and joiners, crank sensor, yes its cost an arm and a leg now,
    put it a signam computor no faults found now says its all ok but its not it wont start, get up in morning, starts on the button then weather i drive it or leave it running for 5 seconds or 5 hours when i turn it off and leave it for 5 mins it wont start and im not sure why have tryed everything,
    please can some one help
    can any one out there shed any light on it as im lost
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    change of font might help!!!!!!!!!!!!! well you might get a few reply's
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    immobilizer fault ?
    north east
    coolant temp sensor is my 2p bet, your raising the e=temp by 1 degree and the glow circut isnt completing so the car wont start, leave it too cool that 1 degree end it starts again.
    out of interest have you ever changed the glow plugs ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    At the very least as roswell mentioned temperature, so it must have some effect. As you can start the car the following day, the engine has cooled down by then so maybe that is the issue.
    Quote Originally Posted by roswell View Post
    He did say he did m8.
    Gazza4
    bristol
    changed temp sensor even if i unplug it it wont start am going to try a in line pump as think its down to pressure of fuel now, if i take off inlet a spray brake cleaner (weaker than easy start) it starts fine, so surly must be to do with fuel pressure!!!!
    bristol
    glow plugs have been changed although 2 snapped had head taken off drilled and helli coiled and put back on
    would like to know if anyone could send or post a photo of the small air pipes that go around engine as not 100% sure if i have them on correctly.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by bryant1066 View Post
    Sorry. Do you have any pictures (or an how 2) of how to change the glow plugs on the 2.0 DTi or is it the same as the one on here?
    http://www.vectra-c.com/forum/showthread.php?t=92988
    Can someone confirm if this will do the job please? Thanks.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    bristol
    is all you need is a 10mm deep socket mate there located at rear of engine with small black plugs ontop of them pull off plugs one at a time and undo the glow plug but be care full there are prone to snapp and then its a very costly job belive me ive been there. best the night before you want to remove them spray loads and loads of wd40 all over the glow plugs and allow to soak over night then once you start job spray again as you are undoing them if they go tight spray and turn other way to work them lose back and forth.
    hope this helps
    paul
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Thanks for the tips. Will give it a go over the weekend.
  1. car won't start :-(
    By michael_linford in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2012, 19:31
  2. Were do i start
    By MCCABE in forum Engine & Drivetrain
    Last Post: 6th March 2011, 21:34
  3. 2.2 sri non start
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 13th February 2011, 00:44
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. 2.2 DTI will not start!!!!
    By Mark121 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2010, 13:02
