Results 1 to 10 of 19
Thread: A note for anyone that needs a switched live for a radio
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Default A note for anyone that needs a switched live for a radio
    Hi guys.
    As I found out today, there is a switched live on the heater controls. It's the red and grey wire. DO NOT USE! You will discover as I have, that the radio will come on and off fine, but as soon as you turn off the blower, the stereo will go on standby regardless of ignition key position. Go a bit further down until you hit the cigarette lighter!
    Hope this saves some of you doing a re-wire!
    Nov 2010
    Maidstone
    Just out of curiosity, ive tried using my cigarette lighter as an ignition live and found it only remains live for lights on the dash, is out of the realms of possibility of using a ignition live from the back of the colour sat nav display at top of dash as that seems to remain live untill key is removed which is what i really need?
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by signum_rob View Post
    Did you use the black wire from the 2pin plug (1black 1brown) connected to the cig socket?
    Nov 2010
    Maidstone
    Well i havent tested the terminals as such, i mearly connected something using using ciggy power (phone charger), and see and which point the power was cut. Also i have an unused wire taped up (grey/yellow), any clues??
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    grey/yellow is for illumination.. so not nessary 12V can be less.. and only on with dash lights.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Ciggy lighter stays live as long as the keys are set to ignition, I power several things this way for years with no problem. I believe VX own single din kit even comes with as wire to join to the ciggy lighter.
    PRESTON
    How do you remove the cigarette lighter to gain access to the wiring. I am messing with an idea, and need a 12v live in that area, thanks!
    Blantyre
    Open your ashtray and remove it and put your hand underneath, pull through the wires or pop the lighter out
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    on the back of the cig lighter there is a plug taped to it i connected my stereo via that m8 and works fine.
    Northern Ireland
    I put my unit to the live feed the black wire but the unit only comes on when the ignition is fully on. Any ideas?
  1. Wot fuses for a live qwn u turn key and a switched live
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 15:15
  2. Were to take a switched live and a live from for a boost gauge
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 15:02
  3. Stereo switched live
    By andyfeeny in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 12:31
  4. What colour is the switched live to the headunit?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 21:45
  5. Parrot 3200 - Switched Live?
    By splund in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2008, 10:08
vectra c ignition live
vectra c switched live
vectra 07 permanent live for radiovivaro constant live for stereovectra c switched power stereoswitched live zafirazafira 2014 switched live feeddoes my vectra c 07 have a permanent live for car radiovectra ciggerette lighter livewhat wire is switched live on vivaro vancorsa c ignition which wires to connect2005 corsa switched live for stereocigarette lighter live wire Vauxhall vectra ccigarette lighter wire for radio Vauxhall vectra cvan ignition live vivarono switched live zafirazafira b stereo ignition liveopal omega switched liveignition live on vectrawhere is ignition live on vectra cwhere is the ignition live wire zafirawhere is a live when ignition turn on in vectra c site:www.vectra-c.comwhere is a live when ignition turn on in vectra cvivaro ignition livecorsa c stereo
