Results 1 to 10 of 14
Thread: 2.2i Reluctant to start
    Regular Member Knuckle's Avatar
    South
    Default 2.2i Reluctant to start
    Hi all, picked up my 2.2 SRI today (2006) and am overall pleased but it seems a little hesitant to start it up?
    You turn the key, and it turns over quite a few times before starting. Any ideas on what is up?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I've posted on your other thread mate.
    South
    Cheers mate . Will get it looked at in the week. Anyone else have any suggestions in the meantime ?
    South
    Guys, sorry to ressurect this but i need to try and get to the bottom of it
    Car has been serviced and scanned for faults this weekend, came back with P1112 which i believe is the swirl flaps?
    That being said, the car does not display any warning lights and the pedal test didnt appear to show anything. They couldnt confirm whether it was a stored fault or a current fault.
    Could this be affecting it starting?
    It is pretty much fine from cold, fine from hot, it's when it has been left for a short while, just turns over for ages then fires up slowly.
    What should i be checking?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    what has been changed in the service fuel filter? any one checked fuel pressure regulator?
    not 100% but don't think pedal trick works on 2.2
    South
    Quote Originally Posted by markj23 View Post
    Thanks for the input,
    Only an oil change and gearbox oil change amongst the little things, so wasnt expecting it to fix it, just got the code read at the same time.
    I phoned VX and it wasnt due for a fuel pump recall if that's what you meant?
    it drives beatiufully, the only issue is literally with the starting which should in theory narrow it down !
    Was thinking about running a tank of 99 through it to see if the extra punch (if it actually exists) might ease it starting.
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    id be checking the battery fella and making sure its charging properly and make sure all leads etc are tight
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No the peddle test wil not work on the 2.2. Have you checked the plugs?
    South
    Are they easy to get to on the vectra? It has a very slightly lumpy idle but otherwise works fine so thought plugs might affect it all the time? Battery is fine it doEsnt have any problems tuning over just kicking in
    Aug 2010
    Luton
    Quote Originally Posted by Knuckle View Post
    very easy sit right on the top
  1. Reluctant start, revs dipping and car with spanner light
    By coldo in forum Engine & Drivetrain
    Last Post: 12th November 2012, 23:51
  2. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  3. Vectra C, 2.2 direct, power loss- reluctant starter
    By Trebor_Lien in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2009, 22:59
  4. Replies: 11
    Last Post: 7th October 2007, 00:57
