Results 1 to 10 of 11
Thread: Brakes
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    Default Brakes
    My 09 elite has developed a loud grinding noise at the back when i apply the foot brake its only there when the car is cold once its warm there is no noise the pads are not worn down am i right in thinking this could be a stone trapped between the disc and pad or is it something more sinister thanks in advance for any help rendered
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Crispy
    it may be grit in the disc,but check the brake shield is not catching the disc before you start stripping down the system
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    id cheeck the inside of the disc, as my rears were doing the same, the outside looked okish, but the inside was worn down due to a knackered piston on the caliper. If there was grit in there i would guess that it would have worked its way out after a couple of drives
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    Wow - I thought I was the only one with this.
    Warm - the noise goes away - I put it down to a light rust coat on the disks as I only drive once every 3-4 days in it.
    Quote Originally Posted by crispy007 View Post
    Did you simply visually inspect the outside rears or remove and measure all four?
    Usualy suspect is the inside pair, which typically wear out first
    Oct 2010
    lincs
    Think i am going to get the local vauxhall dealer to have a look
    when i put this post on here last night i was 120 miles away i have just come home and its making a really bad grinding noise all the time now
    the car is under warranty so i shall be contacting them
    thanks to all of you for your advice
    Nov 2010
    Thanks for the advice - I had not checked the inside pair but what you say makes sense. Thanks.
    Oct 2010
    lincs
    going in tomorrow pm to local main dealer
    no courtesy car but at least its being fixed
    jarrow
    are front brakes on 58 reg vectra wind backs or push backs
    Chelmsford
    My brakes always "scrape" when the car is first used. I always put it down to light corrosion on the discs which rubs off after a few miles
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
