Thread: Wiring Help please
    Essex
    Default Wiring Help please
    Hello,
    I have recently purchased a small blaupunkt active sub to mount under the drivers seat in my Vectra C. The sub requires a + and - power feed and also an audio feed going to one of the cars speakers.
    My question is:
    Which wires running down the side of the car are for the rear door speaker? and also, is there a wire going down the side which is a 12v positive (that could take the power required to power a small amp)?
    If not does anyone know the easiest way I could get power under the drivers seat?
    Thank you
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    you could take power from the rear cigarette lighter.... as for speaker wire colours.. i dont know but i'm sure someone with tis will be able to tell you.
    Essex
    Unfortuntely I do not have a rear cig lighter, it's only an LS.
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    safer to run a the positive wire to the battery and put an in line fuse . if you look under the glove compartment you will see a rubber grumet you will gain access through there
    Essex
    Ok cheers, will do that. anyone got any ideas on the wire colours for the rear speakers? (right hand side if it makes a difference)
    Regular Member razor's Avatar
    Jun 2006
    SHROPSHIRE
    For info Bigdan,
    Right rear speaker - Brown / White.
    Right rear speaker + White.
    Left rear speaker - Brown / Green.
    Left rear speaker + Green.
    Regards,
    Razor.
    Essex
    Jul 2006
    Mexico
    If I was in your shoes I will take david-bell´s advise is always better to hook up from the battery directly...otherwise if you take power from lighter, lights etc. you´ll have two unwanted thigs...first the gauge (thikness) of the wire is usually small...not recomended can cause current, heat, etc. problems....and second this circuits have a fuse....usually small...only intended for little amps....in other words...run a good gauge wire directly from the battery and a fuse specific for the aplication. And the ground one you can hook it from the several points attached to the car metal body, try to connect a new wire for this....don´t split an existing one for better result.
  1. Tow Bar Wiring Help Please
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 10:55
  2. Wiring help please?
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 23:13
  3. I need help with wiring.
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2009, 00:41
  4. Sub Amp Wiring kit
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 22:32
  5. Tow wiring
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2008, 07:57
