Originally Posted by
lesj
The glow plugs will have nothing to do with inj quantity deviation. The deviation is purely to do with the injectors and compensates for variences during the manufacture of the injector.
Each injector has a code on its top that needs to be programmed in to the ECU if a new/replacement injector is fitted, this 'tells' the ECU what deviations (differences) this injector has.
Could be a worn/slightly blocked injector with No 2 being favourite.
Try some fuel system treatment such as Forte in the first instance.
With respect to the P0400-5A code did you clean the area where the EGR pipe connects to the inlet manifold ? The 05A bit relates to low flow, basically the ECU monitors 'total flow' through the inlet manifold using the boost (MAP) sensor.
'Total flow' is made up of clean air as monitored by the AMM (MAF) plus exhaust gases that enter through the EGR.
When the EGR is open the ECU reduces clean air by closing the butterfly valve in the throttle body. If the total flow monitored is low then the ECU suspects that flow from the EGR is reduced.
Could be you need a new EGR, sometimes cleaning does not work or the path of exhaust gasses is restricted.
Hope this helps
