Hi, any V6 boffins out there know if the 8-bolt flywheel>crankshaft pattern on the Y26SE engine is the same as the GM "global V6" range of engines, i.e vaux/saab 2.8 Z28NET/NEL, Aloytec 3.6, LLT 3.6 etc. I want to run the solid flywheel from the Y26SE on one of the later engines, got my clutch options figured out already if it does, just need to know if I can physically bolt the flywheel up?!
