Thread: All straight and ship shape
    Regular Member Keif's Avatar
    In the Garage
    Default All straight and ship shape
    At last.
    I replaced the springs in my Signum last year. I knew that i'd need to get the wheel alignment sorted, but due to a few things it always got put back.
    At the end of last year, I took my XP2 rims off the car and decided i'd get it sorted as soon as possible in the New Year.
    So this afternoon I treated the Signum to a bit of professional adjustment.
    I knew the rear camber was miles out (about 1.5degs both sides). The front was a little out and the Toe angle needed a slight tickle.
    I've used Notthingham 4wheel Alignment Services Ltd a few times before, can only say there service and professionalism is second to none.
    Blimey what a difference. Nice to have a car that actually feels like it should, again.
    Engine : 1.9 CDTi
    Can they adjust the rear camber out as mine is wearing the inside edges.
    in a house
    Had a quick look on my wifes car as she said it seemed to be skipping on full lock at low speeds, found about the first inch on the inside front wheels are quite low but rest of tyre is still at least 4mm tread left, then went to the back and found the same problem.
    Car isnt lowered at all apart from the stuff carried in boot, putting me off lowering it now tbh.
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    What are tge symptoms u need this 4 wheel alignment?? Not sure i had it done when got it lowered, and how much does it cost?
    In the Garage
    Quote Originally Posted by lee gsi View Post
    Yes, my Camber was the main problem.
    Before
    Rear Left
    -2deg 36'
    Rear Right
    -2deg 05'
    After
    Rear Left
    -1deg 27'
    Rear Right
    -1 degs 24'
    Quote Originally Posted by philgst View Post
    Sounds like it needs the wheels aligning then if your having uneven wear.
    Shouldn't put you off lowering your car either.
    If you have a suspension spring snap. You'll need to take the suspension apart. When it's reassembled (fitting a standard spring or a lowering spring) you should get the wheel alignment checked and adjusted anyway.
    Quote Originally Posted by Jow20 View Post
    See my above reply.
    I looked at the car at a Vauxhall Drivers Club meet and it was clear the rear camber was way out. Plus I had uneven tyre wear and the rear kept "skipping" when going round corners.
    Engine : 1.9 CDTi
    Ah thats great,
    Get my inner track rod replaced then get it 4 wheel aligned
    in a house
    what sort of cost would we be looking at for 4 wheel alignment and where's the best place to go around the Staffordshire area, just want it done right if its going to get done
    In the Garage
    Where I went they have a base price (£34.00) then the more that needs doing the more you get charged
    So my bill was
    Wheel alignment - £34.00
    Adjust Rear Toe x2 @ £4 - £8.00
    Adjust Rear Camber x2 @£4 - £16.00
    Total - £58 add on the VAT. = £69.60
    As for somewhere local to you. You'll need have a search and find someone who does 4 wheel lazer wheel alignment.
    north east
    www.alignmycar.co.uk << that should give you your local centre location, if not google wheels in motion they do a great job as well.
    avoid kwick fit and vaux dealers ;-)
    in a house
    Quote Originally Posted by Keif View Post
    So my bill was
    Thats pretty good price that i say,
    isnt even the cost of 1 new tyre to replace due to first 1" wearing down,
    Thanks for the info
  1. Steering wheel not straight, but car drives straight?
    By Danny.surname in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2013, 00:21
  2. Replies: 11
    Last Post: 15th August 2012, 06:47
  3. Build/Test/Ship
    By myworlduk in forum Insignia car chat
    Last Post: 29th April 2010, 17:56
  4. vectra now on ship
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2008, 23:00
