Thread: egr blanking
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default egr blanking
    Would this blanking plate do for my 1.9 sri 120, do i need 1 or 2 http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    You need only one. On mine I mounted tha blankingplate on the exhaust - side of the egr, before exhaust goes in to the egr valve. If you have a 8 valve cdti 120 you will need to drill a hole in the plate. If not the engine will go to limp mode (cdti 120/150 16 valve do not). Fiat has a semi blanking plate with 3x4 mm hole in. It gives a open area 37 mm2. On my cdti 120 i have a 6 mm hole that gives 28 mm2 open area. And its the smallest I could have before the engine goes into limp mode. If you have a 2 mm steel plate you can make this by your self. Just remember two gasket. Good luck
    stockport
    Arrow
    I used one of these on my 150.I blanked the exhaust inlet side of the EGR, (stops it getting gunged up),but didn't need to use any gaskets at all.Everything was fine,no fumes,no smells, nothing!!.Your EML light will come on if you don't drill any holes in it to allow some gases through though.Best of luck. FELIXX.
    PRESTON
    I have read that the 120 doesn't take well to having the egr blanked, but i guess all you can do is try it and see how it works for you. If your car is an auto or estate, blanking the egr might actually cause the DPF to clog quicker, causing the car to go into regen more often.
    The 120 16 valve engine was never fitted to Vectra's, only Astra and Zafira.
    Aug 2010
    North of Norway
    Quote Originally Posted by barney490 View Post
    On my vectra 120 and my zafira with the same engine I drill a 6 mm hole. It will gives a small amount of exhaust flow trough the egr (less then the fiat gasget does). If the hole its smaller then 6 mm the eml light will come on.
    In europe vectra has been sold with the 16 valve cdti 120 engine.
  1. EGR blanking
    By MattDC in forum Diesel Engine related
    Last Post: 15th March 2012, 10:19
  2. EGR Blanking
    By dc6839 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 21:10
  3. Blanking egr
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2011, 18:21
  4. blanking egr
    By nickdti in forum Engine & Drivetrain
    Last Post: 11th June 2011, 07:58
  5. EGR blanking
    By ctj in forum Engine & Drivetrain
    Last Post: 1st January 2011, 02:17
