Results 1 to 10 of 15
Thread: Tyre wear in rear inside edges
    Engine : 1.9 CDTi
    Default Tyre wear in rear inside edges
    Is it the banana shape control arms giving me rear camber and wearing my rear tyres?
    No, just the car design
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by lee gsi View Post
    catch hold of the rear tyre AT 12 O'clock and give it a tug, if its got movment it is the upper control arms/bushes, just gett ing some quotes to have mine done.
    West
    Rear upper control arms are worn, it's the only time any of my Vectras have ever scrubbed the inside edge on the rear.
    Mine have never worn, sent a set of Good Year tyres for inspection in 2008 and they confirmed it was due to rear setup on Vectra C (which is correct)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If it's excessive wear then it's quite possible mate.
    Quote Originally Posted by CLOMP View Post
    although make sure the car is on the ground as the weight needs to be on them
    Very true, while the design of the rear suspension will lead to very slightly more wear on the inside edges it will be accelerated by knackered upper control arms
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Tracking is affected by all components of the suspension effectively - worn suspension components are without doubt going to take their toll on the tyres one way or another.
    One off eh? Neither have mine, but that doesn't mean it's not a reason for worn insides of the tyres in this case.
    Gazza4
    Full Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Mine used to eat rear tyres like hot cakes. I replaced the rear UCAs myself (not a bad job but some bolts fiddly to get to), had the alignment set up professionally and got new (budget) tyres. The car was transformed! It felt lighter, nimbler and more responsive, even despite the tyres being cheap Chinese ones.
    The rear wheels still have some negative camber but it's set up that way for safety reasons.
    If you do have a go yourself, be very careful not to drop any of the Torx bolts as you remove them! I dropped one inside one of the other rear suspension links and had to remove that one as well just to remove the bolt. That meant that I had to get the alignment done straight away because I had to remove the eccentric washer in the adjustable linkage. Not much fun, that part!
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Quote Originally Posted by Gazza4 View Post
    Most of my tyres go back to manufacturer for inspection, unless they are worn evenly down to the minimum perfectly
    It was quite obvious on that set of Good Year tyres, as it was the only time I did not rotate them rear to front, as the fronts wore
    They had 30K miles on the rear, instead of the normal 10K miles
    Both inside edges were perfectly down to 0mm, 3mm on the outside edges, and 1.6mm across the central three quarters of the tread
    Two other tyres went back earlier this year, Good Year confirmed both had failed due to manufacturing defects
    Again, they commented the wear suggested it had been fitted to the rear, due to the wear pattern
    I checked the tyre batch code, and indeed was the tyre that had been fitted to the rear
    As always, on fitting new tyres, check the suspension, check the tyre pressures, then have a full four wheel alignment carried out
    The rear tyres will still wear on the inside edges!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I prefer to go to a tyre fitter get the tyres changed when they have reached their legal tread life or if the weather has affected them prematurely. Most do that. Tracking gets done every 2/3 years. Tbh that's normal.
    Gazza4
  1. what would cause inside tyre wear?
    By krazylegz in forum Suspension, Wheels & Brakes
    Last Post: 6th June 2012, 05:55
  2. what would cause inside tyre wear?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 23:10
  3. wear in inside edge of rear tyres
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 23:45
  4. Rear Tyre Wear
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2008, 22:20
  5. Rear tyre wear
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:10
gsi 3.2 rear tyre wear
tyres worn rear inside edge
vectra c rear tyres worn inside
vectra c rear tyre badly worn inside
rear tyres wearing badly on the inside on vectra c sri
abnormal tyre wear on rear tyres vectra
back tyre wearing on the inside vectra
Insignia tyres wearing on inner Edge
what is causing tyre scruboninside rear vectra c
rear tyres worn on inside edge
rear tyre wear inside edge vectra
vectra c rear tyre wear
vectra c worn banana arms
why do the tyres on back of my vectra wear on the inside only
tyres worn on inner edge vauxhall insignia
vectra c banana arms
vectra c rear inner tyre wear
vectra c rear tyres worn on inside
rear tyres worn on inside edge on vectra
vauxhall insignia rear tyre wear
vectra c excessive inner tyre wear
