Results 1 to 3 of 3
Thread: Emisions light and other faults
    Regular Member coldo's Avatar
    Scotland
    Default Emisions light and other faults
    Hey all,
    Been having some issues with the Vectra Recently...
    About a month and a half ago the emissions light came on the car and stayed on. The car drove fine and once i cleared it with OpCom it never came back on.
    It came on again today with a few other faults so I thought i would post what the faults are acording to OpCom to see if you guys can help me find out what is wromg with her...
    Oh, and the cruise control works fine so am not sure what is wrong with that and the other fault is for the three line display stock wich i have not yet fitted... I have this preped for when i install the three line display.
    DIAGNOSTIC REPORT:
    OP-COM 090714
    Please add your workshop
    name in the settings window
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0014
    VIN: W0L0**************
    Part Number:13165350
    Software version number: 12244872_
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 040513
    Number of stored fault codes: 2
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    B3750 - Switch Info Display Circuit Open or High Voltage
    (04) - Present
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0206
    System name: Z18XE
    Hardware number:2001000
    Part Number:55354416
    Software version number: 6577915104
    System description: SIEM 0100
    Type approval number: S04004
    Alpha code:
    P0036 - O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2)
    (08) - Present
    P0136 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    (11) - Not present
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x0101
    Hardware number:0
    Part Number:9191495
    Software version number: 0348C33E
    System name: ABS EBC430
    System description: TRW 0300
    Alpha code: EM
    No fault codes stored.
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0104
    Hardware number:24444336
    Part Number:0
    Software version number: V20_
    System name: EHPS GEN3 TRW
    Alpha code:
    U2105 - CAN-Bus no Communication with ECM (Engine Control Module)
    (00) - Not present
    U2105 - CAN-Bus ECM Message Range/Performance
    (71) - Not present
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x0102
    Part Number:13144226
    Software version number: 8.39 16/03
    System description: VDO 0400
    Alpha code: UB
    Manufacturing date: 040524
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0101
    Part Number:13170590
    Software version number: 0C0C3303
    System description: 0x41533035393053303330393832334320
    Alpha code: DW
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0208
    Part Number:13168783
    Software version number: C12C93 08041404
    System description: TEMIC04
    System description: 0x20202020202020303030363733363230
    Alpha code: EJ
    Manufacturing date: 000400050105
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0102
    Part Number:13170888
    Software version number: 000007D1
    System name: REC
    System description: LEAR 0400
    Alpha code: CW
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0202
    Part Number:13170900
    Software version number: 000007D0
    System name: UEC
    Alpha code: CS
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0103
    Part Number:13170163
    Software version number: OP1D 190000
    System description: SIEM 0401
    Alpha code: EK
    Manufacturing date: 615040
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0103
    Part Number:13170150
    Alpha code: EM
    Manufacturing date: 715040
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x0001
    Hardware number:13114365
    Part Number:13114366
    Software version number: 4601
    System description: BORG 0400
    Alpha code: YQ
    Manufacturing date: 040413
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    (08) - Present
    Maybe the Lambda sensor after the cat might be away, but that's just a guess. I had the 0036 fault code but seems to have cured itself after I replaced the thermostat and the engine now runs at the correct temp.
    Have you tried resetting the fault codes and seeing if they come back up?
    DERBY
    I had a p0136/p0141 code mine was open circuit on the heater on no2 o2 snsr check for continuity on the 2 white wires of the snsr if no continuity the snsr will not warm up on its own , easy to change got one from car parts connection £45
  1. U480 code reader picking up no faults? Spanner Light is on though....
    By the1theycallthe1 in forum Engine & Drivetrain
    Last Post: 10th March 2016, 14:11
  2. emisions
    By Ray_Ray280 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 17:45
  3. engine light on but no faults?
    By mackemade in forum Engine & Drivetrain
    Last Post: 5th July 2011, 07:45
  4. "help" exhaust emisions light
    By david-bell in forum Engine & Drivetrain
    Last Post: 9th December 2008, 22:07
  5. emisions light ? on dash board
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2008, 20:35
