Thread: Fan belt / Drive belt
    Oct 2009
    bristol
    Default Fan belt / Drive belt
    Could anyone advise me what the big pulley at the bottom of the engine thats on the belt connected to the alternators ect. as the larger pulley seems to have a wobble on the go. could anyone advise me of what the possible implications of leaving this pulley wobbling could be?
    Vectra C 56 Plate 1.9 cdti
    Exclamation
    It sounds like your pulley is starting to come apart, best to get it checked out before it does or you will be at best stuck at the side of the road when it does.http://cgi.ebay.co.uk/Vauxhall-Vectr...item35a9b0c86e
    They have a rubber insert in them that starts to come apart.
    West Sussex
    Quote Originally Posted by patdavis View Post
    If it's got a wobble now it's going to come off at any time. It happened to mine last year, started off with a vibration, followed by a loud noise and me going nowhere. I don't think it's the easiest DIY job due to the ridiculous pressure needed to get the stretch bolt out, saying nothing of access. As I recall Vauxhall wanted about £300 for the work. I took mine to a local garage with a pattern part (crankshaft pulley) and it's never really felt right since.
    With hindsight I wish I'd gone to the main dealer on this occassion.
    On the 1.9 the crank pulley is usually held in place by the four small bolts alone (mine is)but I have read of other owners cars that had to have the centre bolt removed as well before the pulley could be removed.
    West Sussex
    Quote Originally Posted by Rapala View Post
    Good point, mine is a 2.2 dti which is an older engine.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as rapala says 4 bolts to remove pulley,the Dti is held with the centre bolt
    Oct 2009
    bristol
    yes mine looks as if it has 4 bolts.. is there a part number for this item?
  1. drive belt tensioner
    By coooky in forum Engine & Drivetrain
    Last Post: 24th January 2012, 04:14
  2. Drive Belt help
    By SRIstu in forum Engine & Drivetrain
    Last Post: 11th May 2009, 11:10
  3. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
  4. Aux drive belt...
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 6th October 2007, 10:26
vectra c drive belt wobble
does the vectra c have a fan belt
vectra c 1.9 crank pulley wobble
1.9cdti crankschaft pulley wobble
