Thread: Vectra C Blower - How to Change
    Bristol
    Vehicle : Vectra C 2.0 DTI Elite
    Engine : Y20DTH
    Mileage : 168K
    Default Vectra C Blower - How to Change
    Hi all,
    First post ... have searched for about 30 mins but cannot seem to fnd instructions on how to change the blower fan on a Vectra C 2004 DTI Elite.
    The blower does not work on any speed (so I don't think it's the resistors) and grey smoke came out from the fan area (behind the glovebox) AND my local garage told me it's the blower. However I do't have a spare £400 lying around, so I have just ordered a replacement blower for £100 from ebay, but wanted to find some instructions (with pics) on how to change it .. otherwise, it's another £100 to fit.
    Can anyone help ?
    Many thanks
    TK
    Apols if this is in the wrong forum
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    You've probably fixed this now but just in case...
    http://www.blower-motor-resistor.co....-resistor.html
    Wakefield
    Default fan
    it will take you about half hour mate did mine at weekend take the glove box out then you can see fan theres 5 torx screws holding it in remove them and the fan will come out your prob only get fan not the plastic caseing the fans held in with 3 torx screws you should have gone to breakers yard mine cost me £35 if you get stuck send me a measge and ile try me best to help
    Regular Member Innes's Avatar
    Plymouth
    I took mine out to get to the air recirculating motor. It wasnt to bad. Just a bit cramped for a 6'3" chap like me. I used the Haynes Mannual for the instructions. Allways worht £18 especially if you plan on doing work on your car.
  1. Heater / Blower Not Working Properly (2006 Vectra 1.8)
    By bigboynigs in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 16:31
  2. Heater Fan Blower. Vectra C
    By Milden in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 20:22
  3. wanted heater blower motor vauxall vectra c
    By Les45 in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2011, 08:21
  4. Blower won't switch off - vectra c 2.2
    By mattrobins in forum Bodywork & Interior
    Last Post: 4th February 2011, 12:11
  5. vectra 1.8 oil change
    By craiggaler in forum Engine & Drivetrain
    Last Post: 9th January 2011, 18:30
How do you change a heater blower on a vectra c
remove geating fan vectra c
How to change a heater blower motor vectra c
changing a vectra climate control blower
replace fan vectra c
how tochange heater fan on vauxhall vectra 2004
vectra c blower motor removal
