Thread: Fuel out of exhaust
    Oct 2010
    West Wales
    Default Fuel out of exhaust
    Hi all,
    My first post!
    2006 Vecy 2.2 Direct 48K ......misfire on motorway with white smoke....called RAC...... Misfire on No1 says the reader, coil pack says the RAC man. New coil pack and plugs fitted, still the same but no fault code, billows of white smoke and petrol running out of exhaust!! No 2 plug and piston top soaking in fuel, injector stuck open? ECU?
    Any advice would be much appriciated
    Pete
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    I'm guessing you've tried a new spark plug too?
    Regular Member LADmachining's Avatar
    Hampshire
    Have you run any basic checks on the engine, such as a compressions, leakdown and coolant pressure test?
    Oct 2010
    West Wales
    Yes, changed the plugs as mentioned.
    Have not done a compresion check yet but no oil in water or water in oil, engine feels fine to turn over by hand but will do a comp check.
    local VX dealer has not got a clue, will remove injectors and have them tested.
    Thanks Pete
    Oct 2010
    West Wales
    Took injector rail off and found that the No2 injector was stuck wide open, £90 for new one. All reasembled but ran like a bag of poo, probabally due to ECU and many other electrical plugs being disturbed. Cleared fault codes with an RAC code reader and all is well.
  1. Replies: 5
    Last Post: 3rd January 2013, 21:56
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Replies: 19
    Last Post: 30th May 2012, 15:53
  4. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
