Results 1 to 10 of 14
Thread: Handbrake Cable - Tightening on a Corsa C
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Default Handbrake Cable - Tightening on a Corsa C
    Any ideas anyone? I know it is a Corsa but quite a few of you guyswork on them too
    Thanks muchly people!
    Regular Member danlat1415's Avatar
    Lancashire
    sorry to jump on your post, but will it be the same as the vectra, because mine is getting quite high now...
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by CDTi
    What model year and engine mate? I will have a look at TIS and send you some PDF's if you like?
    Dave
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    I thought that most modern cables were "self adjusting" these days.... the last time I adjusted a cable was on an escort ages ago and it was full of piddly little plastic clips that broke as soon as I touched `em....good luck mate....
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Our Corsa C handbrake was sh!te in all the 4 years we owned it.
    Jul 2006
    Cheshire
    How's this?:
    Parking Brake, Adjust
    H907500
    Note: Before adjusting the parking brake the drum brake must be set on vehicles with drum brake
    Remove
    1. Unclip gaiter of parking brake lever (1) from centre console and pull upwards.
    2. Turn back adjusting nut (3)
    Note: The adjusting nut (3) must be turned back fully
    • Depress brake pedal fully at least 3 times
    Note: To adjust the play on the parking brake at the brake calliper or drum hum
    Note: The adjustment lever may no longer be heard to skip.
    3. Tighten parking brake lever (2) as far as the 3rd notch
    • Turn adjusting nut at parking brake lever until the rear wheels can still just be turned
    • Tighten parking brake/drum hub to the 7th notch
    Note: The brake must now be firm. The braking effect must be equally great on both sides
    Jul 2006
    Cheshire
    Quote Originally Posted by danlat1415
    From looking at TIS and personal experience of changing rear discs and pads I don't think that any adjustment is not possible or necessary on the Vec-c. The hand brake does self adjust by way of a special pair pistons on the rear pads, when the pads are changed these must be both turned clockwise and pushed at the same time back home into their carriers, perhaps your rear pads are getting low if the hand brake feels tight? Have you had a look at them recently or noticed any squeeking from the back when braking? The pad wear sensor only exists on the front nearside so you will not see a warning if this still has sufficient meat on even if other corners don't.
    HTH
    Dave
    'Norf Yorks.
    Thanks mate!!!
    Jul 2006
    Cheshire
    No worries
    Dave
    Jan 2006
    Hornchurch
    you will just need a 10mm socket long one
  1. handbrake cable
    By mbtech01 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2013, 16:47
  2. Tightening handbrake??
    By SlowCoach in forum Suspension, Wheels & Brakes
    Last Post: 17th December 2012, 02:41
  3. Handbrake Cable Tightening
    Last Post: 23rd April 2012, 10:49
  4. Handbrake cable
    By peadar in forum Vectra C / Signum Troubleshooting
    Last Post: 10th June 2008, 07:57
  5. handbrake cable
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 12:49
vauxhall vectra c handbrake cable
adjust park brake vectra c
vauxhall corsa handbrake cable how to adjust
corsa c handbrake cable loose
corsa c handbrake cable wont adjust
how to adjust handbrake 2012 corsa
how to adjust corsa c rear brakes
corsa.c adjust.handbrake
changing handbrake cable corsa c
vauxhall corsa c drum brake adjustment
how to tighten the handbrake cable on a opel corsa lite
corsa c adjust handbrake cable nut
handbreak layout on corsa c
corsa c adjusting brake drum
corsa c drum removal
where is the nut to tighten handbrake on corsa c on axel
https:www.vectra-c.comforumshowthread.php12599-Handbrake-Cable-Tightening-on-a-Corsa-C
corsa c handbrake adjustment
corsa handbrake maintainance
how to tighten handbrake cable on vectra c
