Results 1 to 10 of 11
Thread: just a question about the recirculation valve.
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    Default just a question about the recirculation valve.
    Hy
    I`v found my recirculation valve stop working....it has the toothed wheels from inside broken...
    I found another one on the internet and just want to know if will fit on my LHD Signum the recirculation valve from an Vauxhall Vectra C witch is RHD (from England)...
    Or I need just to put the little wheels from the good one to my recirculation valve?
    Thanks.
    May 2007
    Norway
    Perhaps you have a picture of the failing part? -Not sure what you mean with "recirculation valve" and toothed wheels inside of it...
    Or perhaps you can post a link to the part on internet you are about to buy?
    In general for engine parts, if the engine code is the same for your Signum as for the Vectra C you are about to buy parts from, they will most likely fit.
    Jul 2009
    Bistrita
    I have the picture with this part....
    But i`m asking if will fit the part from an Vectra RHD to my Signum LHD ...
    This the part...
    And I know this is a common fault at this cars...
    May 2007
    Norway
    Aha, now I understand which part.
    The motor/actuator for the Ventilation Recirculation has GM-partnumber 131920136845105 and should be the same for Signum/Vectra in LHD and RHD.
    Jun 2009
    Middlesex
    I think mine needs to be replaced.Whenever i lock/unlock the doors i hear this clicking noise for 3-4 seconds.Am i right in saying that this valve (i.e valve closes when car is locked to prevent circulation of air into car to prevent alarm being set off).Where is it located ? Is it easy to change?
    Dobs
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Dobs View Post
    Dobs
    Yip mines does it. Pressing Recirculation button causes the same noise too.
    Gazza4
    Jun 2009
    Middlesex
    Is it worth changing?Easy or not.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Apparently is it do-able but a complete pain. I had a look and there's not alot of room.
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's easier if you drop the heater motor out
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Mine was clicking on ignition so had a look today.
    Couldn't get the ****** thing off.
    So I disconnected it.
    The clicking has stopped and everything else seems to be working.
    This won't cause any damage having it disconnected will it?
  1. Fault code po403 exhaust gas recirculation valve.faulty.
    By Dobs in forum Engine & Drivetrain
    Last Post: 8th September 2012, 13:37
  2. EGR Valve question about cleaning
    By steeley7 in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 17:09
  3. EGR Valve question
    By CH-VECTRA-ELITE in forum Engine & Drivetrain
    Last Post: 8th July 2011, 16:11
  4. P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:19
  5. Another EGR valve question
    By aerodynamic18 in forum Diesel Engine related
    Last Post: 11th February 2011, 18:39
vectra c heater recirc clicking
vectra electronic recirc valve
vectra c recirculation actuator
vectra c air recirculation motor
vectra no heating until recirculation is pressed
