Thread: Centre dash airvents/CID removal?
    Glasgow
    Default Centre dash airvents/CID removal?
    Hey guys,
    When changing a centre air vent next to the CID do the vents come singley or as a pair? Also does the screen need to be disconnected and if it does would it need re-programmed upon re-fitting?
    Hope someone can help cheers guys
    Blantyre
    Comes out as one unit (pair )
    Screen does need to be disconnected, but will reconnect straight back in, no re-programming needed assuming its going back in the same car
    WGAF#5
    there a pair - if your just disconnecting the screen and refitting it to your vehicle (matched unit) then it wont need reprogramming
    pull the long trim off under the display (open the glovebox to give you a purchase point) its just clipped in then you will see the torx screws that hold the display and air vents in place
    Glasgow
    Thanks guys much appreciated. Its the VXR im buying i told them im wanting one of the vents replaced someone had broke it by using one of those air fresheners that fits onto the vent slots. Its not a VX garage so was just hoping i dont have to wait on them taking it to a dealers so thats good news.
    I just hope they dont damage anything trying to work out how to get the vents off now
  1. Gsi centre box removal
    By larrysSRI in forum Petrol Engine related
    Last Post: 2nd November 2012, 20:07
  2. Centre Dash Speaker
    By DeeBe in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2012, 09:13
remove dash air vent vectra c
screen removed Al vectra c
vauxhall cid removal
hod to change the vents in a vectra
vauxhall vectra c centre vents
