Thread: how long should a Thermostat take to reach temp
    Jul 2010
    rotherham
    Default how long should a Thermostat take to reach temp
    Right im having abit of a problem with my 2.0DTI, the mpg have rapidly decreased, and i mean rapidly it just seems to be eating fuel. Posted some threads on here and everybody said about getting a service which i am on Saturday, but also somebody said that it would be my thermostat not working right. The thermostat sometimes stays on 0 and then other times it come of and is any where between 80/90. The Car heaters do only work on Level 4 but thats the resistor pack i think its called, but apart from that my heaters do get warm, it just takes around 10 minutes.
    I had the car put on 2 difference computers at the garage and they said that my turbo and everything is fine, the only faults it found were something to do with a clutch switch and a glow plug not working. (the glow plug snapped).
    Anyways he said that he qould supply and fit a new thermorstat for £30 so do you think i need this doing. Its not a bad price so dont mind paying it but then again if i dont need a new one then its pointless paying out.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    Cant argue at that price tbh. Does seem to be an absurdly common fault across the whole Vec range.
    It's only a common fault as a lot of the cars are now cheap and getting old. It's mainly but not only the older models.
    Jul 2010
    rotherham
    So do you think it needs changing or not? Also iv just bought some of that castrol magnetic oild 5w30, if i take that to the service place do you think the garage will knock me money of the service?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Your description of it heating up sounds about right for a DTi tbh, they do take a while to heat up but if it makes you feel better then get the stat changed.
    You mentioned in another thread you had a spanner light on, has this been investigated yet?
    Jul 2010
    rotherham
    Yes had it on the computer im guessing it becuase of the glow plugs.
    The computer only showed 2 faults the clutch switch and glow plugs.
  1. Thermostat or temp sensor
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2013, 08:07
  2. Is it the temp sensor or thermostat 1.9cdti
    By bennettboy in forum Engine & Drivetrain
    Last Post: 28th October 2012, 12:45
  3. Thermostat or temp gauge or nothing?
    By mrpoochie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2012, 12:11
  4. thermostat & temp sensor
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 16th December 2011, 12:37
  5. cant unplug my temp sensor on my thermostat
    By justin32 in forum Engine & Drivetrain
    Last Post: 10th December 2011, 16:16
