Thread: Cruise Control.
    Durham
    Default Cruise Control.
    The Cruise control on my car seems intermittent? - As of right now, its not working, When i press the button on the left hand side to activate it, it does nothing, so i have no cruise control.
    But last week it wasnt working, I pressed it just to see what happened and it worked all the way home, on and off etc...
    Could this be a loose cable in the system? - Has anyone had this problem before and is it easily repaired?
    Many thanks
    Adam
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Could be the clutch pedal switch, seems to be a common issue really.
    May 2008
    Tyneside
    Clutch return spring, common problem, think there is a modified one available. Try lifting the clutch pedal then engaging cc.
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    make sure your left foot is not resting on clutch pedal when you set it.
    thats what i was doing
    Bristol
    Vehicle : CDTI 150
    Quote Originally Posted by tridley View Post
    There is indeed a modified spring
    13 Post(s)
    Also the CC won't work until the brake pedal has been pressed once. I don't mean every time you want to use the CC. It needs to be pressed when the ignition is next switched on.
    Antwerp, Belgium
    could be the CIM behind the steerinng wheel
    had this on mine. Not cheap.
    so i hope for you that it is the spring
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Quote Originally Posted by sliderke View Post
    Is there a test for the CIM?
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
