Thread: Problems with Starting Car
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Problems with Starting Car
    The car is auto transmission.
    Over the last week I have had a slight problem starting the car.
    When I switch the ignition on the car goes through it’s checks as normal but upon completion the display on the dash where it indicates it’s in P, D or R, 1, 2, 3 etc is displayed as a dash and the anti skid light and the symbol next to it (not sure what it is) on the dash stay illuminated and the car will not start, just no response whatsoever.
    If I switch the Ignition off and do the procedure again it seems to be OK.
    This has happened on 3 occasions in the last 10 days, any ideas of what the problem can be?
    It's a 1.9 CDTi 150
    Many Thanks
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    EDIT:
    Power Assisted Steering Symbol.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Anybody?
    Regular Member Exclusive BV's Avatar
    West Midlands
    Could it be a dirty micro-switch on the gear selector somewhere?
    I am no expert but there must be one somewhere which tells the car not to start unless it's in park
    Try to locate it and give it a blast of 'pressurised air' to clean it out
    There must also be a switch of some sort on the brake pedal too i would think
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Both the Power Assisted Steering and Anti Skid Symbol lights are on permanently and am not able to start the car.
    Any ideas?
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Problem was the UEC Realay (whatever that is).
    Repaired under VX Extended Warrahty
  1. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  2. starting problems
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 17th September 2012, 10:03
  3. Starting problems
    By Venom1924 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 23:55
  4. 2.0 dti starting problems
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 11th October 2011, 18:47
  5. problems starting
    By jasoncow in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 23:24
