Results 1 to 10 of 24
Thread: Weird rear lights
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    Default Weird rear lights
    I have just noticed that my rear lights are acting up. I have seen a few vectras driving around my area at night and they seem to all have the rear lights and brake light lit up all the time but the brakes get brighter when pressed. My car on the other hand only has the rear lights lit up and no brake light. But when i press the brakes they light up in the right places. I dont have any bulb failures come up so i'm puzzled. has anyone else had a similar problem. pics included.
    Wales, UK
    To be honest mate, im sure thats how mine is. Im sure I have seperate light segments for the brake lights. I was under the impression that the Vec smartly uses the tail/side light segments as brake lights when there are actual brake light errors...
    Wales, UK
    Ill go look now this has confused me lol
    Regular Member badback's Avatar
    Runcorn
    Have you tried swapping the bulbs?
    Wales, UK
    Ok, just been out - I was wrong.
    Side lights switched on, the whole cluster is lit up. Then when I press the brakes, only the small strip, just below the indicator segment gets brighter.
    Thats an odd one. Unless it has something to do with model/year.
    Mines a 58 SRi.
    Quote Originally Posted by mark_647 View Post
    Mines a 58 SRi.
    every other vectra ive seen does the same as yours. For some reason mine does it differently. I cant see it being the bulbs as they work when I use the brakes. Will try swapping them round as suggested
    Sodding Typical on Sea
    Being a twin filament bulb in the stop / tail if one has blown does the Canbus not compensate and knock the matching other out as well? if this was the case I would wonder or expect you to have a bulb failure warning and as you have not mentioned that I am left very curious, as mine light up the whole red area not just the lower on sidelight settings.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    it should NOT be twin filament bulb in any lights for the vectra/signum.
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    They are all single filament 21watt lamps the electronics reduce voltage on normal rear lamps to max 5 watt which is what they should be
    yeah as above only one filament bulbs so thats not it. will try changing them tomorrow and see what happens
  1. Weird things Happening Please Help Me On This One! ABS\Dash Warning Lights
    By Street Hawk in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2012, 12:06
  2. Weird problem with heater blower only works with the lights off
    By evhop in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2012, 22:02
  3. Additional Lights in Boot - WEIRD problem
    By NealM in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2011, 13:03
  4. rear brake lights weird!!!!!!!!!
    By dobby in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:35
  5. weird dash lights wont go off !!!!
    By mikaj in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2009, 21:03
