Thread: 2.0 tdi fault light
    east sussex
    Default 2.0 tdi fault light
    hi all, wifes car got a fault light come on a few days ago, tried to get vx to read it for free but they want £48+ vat.
    i could spend hours trying all the tips posted so hoping someone can help.
    this is my first post so sorry if it's already been answered.
    Devon
    87 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Only way is Tech2 or Opcom maybe someone in your area will be able to help read codes or you could try the pedal test.
    Might be best to give some more details like is light on all the tine, Is car in limp mode , Is car running right ?
    Irmscher Insignia CDTI 130
    east sussex
    thanks for the quick reply, car has little power, still runs, i guess this is called "limp mode".
    the light started intermitantly and now is on all the time. i notice over the last few months that when on idle it wasn't running smooth all the time but soon went when warmed up, this may have been the start of the problem ...
    is there anyone in the eastbourne area with a tech 2 ?
    i see people have tried a pedal test but does it work on this car ?(2004)
    thanks in advance
    Wirral
    6 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Pedal test won't work on any DTi engine. Is it the emissions or ECU warning light on?
    east sussex
    car with spanner. is that emissions or ecu ?
    east sussex
    just remembered that the temp gage was playing up at the same time as the fault started...hmmmm have i just diagnosed my fault????
    anyone know if the teach 2 on ebay has the correct software and can clear codes?
    Nottinghamshire
    Some faults need to be reset via Tech2 or similar once they have been fixed whereas others just disappear immediately after the fault condition disappears or a short time later.
    If you think you have found the fault, you can fix it and then see if the fault light disappears by itself. If not, disconnect the battery negative terminal for half an hour and see if that does the trick. If not, the fault light will need resetting via Tech2 or similar.
    The fault code reader / resetter options for the DTi are Gendan's Vauxcheck for £80, Opcom / Vauxcom from Ilexa for about £600, or Tech2 for heaven knows how much.
    East Midlands
    Here's a list of common faults that seem to happen more often than not with the Dti.
    1/Check the 2 hoses on top of the engine as you look down both left and right,they tend to start with a small split which gets larger over time,eventually throwing the fault on permanently.
    2/The vacuum hose ends which are made of perishable rubber tend to split,this puts the fault light on..Check all small vac pipes and rubber joiners for splits.
    3/? MAF sensor..needs to be tech 2d for that common fault.
    4/ Check the EGR valve for operation,Look on here for the "how to".
    Try numbers 1 2 and 4 in that order before looking at the Maf..hope this helps.
    east sussex
    many thanks, will have a look later.
    east sussex
    thanks for all your advice peps, had the friendly mech out this morn after i check a few bits myself, he read the fault as one of the following.
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    not sure exactly which 1 as i wasn't looking, he showed me a vauxhall update that advised to cut 1 wire at the sensor, he did this and the code was clear and car seems fine as i drove round the bloke.
    seems like a quick fix and not sure if already posted as could save a few quid !!
  1. ABS fault light
    Last Post: 5th October 2012, 19:04
  2. fault light ??????????
    By iam2103 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 08:46
  3. fault light
    By homerj in forum Engine & Drivetrain
    Last Post: 19th September 2010, 15:56
  4. fault light
    By trev16185 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 19:56
  5. TC AND ABS LIGHT Serious Fault
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2008, 19:49
vauxhall insignia p0402
vauxhall insignia p0402 quick fix
