Results 1 to 3 of 3
Thread: advice please
    Sep 2009
    middlesbrough
    Default advice please
    hi everyone i used to be a member on this froum when i had my old vectra sri cdti 150 but i sold it, anyway im looking to buy another one, its a facelift model and its a very good price but it has an intermittent issue with accelerating, before the turbo kicks in every now and again it will struggle to build revs and its a bit lumpy, then its off like a shot when the turbo kicks in, its a 1.9cdti 150, could it just be an egr valve or could it be something more serious, also how much should i be looking at to get the cambelt changed as its due soon and is there any way to check for the dreaded flywheel failure? car has done 98k, cheers in advance
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Could be EGR, could be 3rd Injector (depending on the age >2007), could also be a knackered inlet manifold (with the swirl bar coming off). The EGR can be cleaned at no cost, new injector wiring £15 and new inlet manifold anything over £600 to over £1000 from VX.
    The cambelt job can vary, kits are about £135 and some places can do it for a hour or so labour, some a couple or more.
    The flywheel, if knackered will make a rattling noise (initially) with the clutch half pressed (from the near side of the engine bay) and will eventually do it the whole time the clutch isn't pressed - this can be an expensive repair.
    Sep 2009
    middlesbrough
    Cheers for the reply, when I go to see the car I will check the clutch, it's a 55 reg, will I be able to see if the rod has come off easily enough therefore needing a new inlet manifold, then if it's still attached I'll be able to just get a new egr valve? Cheers again
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
