Results 1 to 3 of 3
Thread: Z20NET Turbo sensor bits.
    Regular Member 111's Avatar
    Stockton-on-Tees
    Default Z20NET Turbo sensor bits.
    Are the 2 sensors in the pic, the ones that control the turbo and should be both changed at the same time. Mine seems a bit slow to spool up. and what are they called & cost. thanks in advance
    Regular Member Jezzy's Avatar
    S.E
    The part numbers are listed in the Z20NET Spec Sheet thread above yours in the tuning section, one is as listed by me, the other is added by Deztroyer. They aren't the bits you've circled though (that's the ECM under there). Directly to the left of the throttle body (on the right hand edge of your red circle) is the one Dez mentions the part number for; the second one (that looks identical to the first) is under the "12" label in the picture above (to the left of the turbo). About £25 for the pair; if your local Vauxhall dealer doesn't have them in stock, try your nearest Saab dealer as well.
    Stockton-on-Tees
    Thanks Jezzy, I did try a search but didnt know what they were called
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  3. z20net turbo
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 08:55
  4. Z20NET 02 sensor
    By anthonytodd in forum Parts for sale
    Last Post: 16th February 2008, 19:34
z20net sensor part numbers
