Thread: Idling issue
    Cwmbran/Newport
    Default Idling issue
    Hi all, having slight issues whilst the car idles, seems to be higher than normal, recently changed air filter, any ideas what could be causing this? Cheers Matt
    West London
    at a guess I would say to first re check your work done when changing air filter, make sure all connections are done up properly. Especially the big hose of the air box, both ends.
    Cwmbran/Newport
    Just checked, all seems ok, anything else i could check?
    Cwmbran/Newport
    Default Found the problem
    Just checked again and could hear air escaping, moved a hose and it appears to have snapped, its also been affecting the brakes. Will try and get a photo soon, but the pipe runs from the drivers side over to just infront of the water bootle (2.0t). Any ideas what it called?
    Cwmbran/Newport
    Default Image as promised
    Image of the offending tube/pipe
    Cwmbran/Newport
    The green arrow is where its split.
    PRESTON
    That is the brake vacuum pipe, if it is split it WILL cause idling variance and the brakes will be affected, as this pipe creates the vacuum for the brake servo to work. Temp repair with tape, but it needs changing,, pronto!!
    Cwmbran/Newport
    Thanks barney, any ideas on where to get a new one and cost?
    PRESTON
    Cost i can't help with and i guess that will be a dealer part only, sorry!!!!
  1. URGENT HELP: Zafira 2003 1.8XE poor running issue, not idling
    By merikiito in forum Engine & Drivetrain
    Last Post: 17th May 2012, 17:34
  2. idling rough
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 16:21
  3. 2.2 idling
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:00
  4. Idling
    By Daywalker in forum Engine & Drivetrain
    Last Post: 10th May 2008, 08:23
  5. Eratic idling
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2008, 21:08
