Thread: rear pad replacement
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default rear pad replacement
    hi guys, i've had this noise from the rear of the car for a week now, and on inspection there aint a lot of meat left on the pads,especially the inner ones, so i'm going to need to replace them, is there anyone local who has the tool to rewind the pistons, who fancies doing it for me in exchange for beer tokens,,,,you don't have to do it all just lend a hand....cheers
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    G Clamp should do it
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    I done mine with a long nose plier, very easy though. But you will need to find the right torx socket for remove two caliper bolts per side, i done this with a 16mm(or 14mm?) socket and a hammer. Personal suggestion is to replace this 4 bolts (2 per side). Other stuffs will be very easy.
    13 Post(s)
    Quote Originally Posted by mxt View Post
    Eeeek!!! Ignore this suggestion. The piston needs to be wound back in, not pushed as it has a spiral thread cut into it.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    G clamp will work on the fronts but not the rears.
    Nov 2010
    Thanks for the correction - not realised that on the rears they needed winding in
    Jul 2009
    The Rift, Cardiff
    Pointy nose pliers should work as long as the pads haven't worn too much and the piston is fully out. My rear pads were almost to the metal when a replaced mine, the piston just would not catch the thread. I ended up borrowing a rewind tool with a flat plate and had to carefully turn the piston with large grips while turning the tool mm by mm.
  1. Rear Pad Replacement
    By Fozman in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2009, 21:38
  2. rear pad replacement
    By campbell1987 in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2009, 20:07
  3. rear pad replacement
    By paulf in forum Suspension, Wheels & Brakes
    Last Post: 31st October 2009, 20:23
