Thread: Engine number location (Z19DTH)
    Engine : 1.9 CDTi
    Default Engine number location (Z19DTH)
    I need to order a DMF and clutch for my car.
    There are 2 clutches listed (Big difference in cost too)depending on engine number.
    Where is it?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    on your log book ..i take it your not getting them from vx ....
    Regular Member LADmachining's Avatar
    Hampshire
    Or on the car pass.
    The number is physically stamped into the edge of the block, where it meets the gearbox, under the EGR cooler.
    Engine : 1.9 CDTi
    Vauxhall want to much money and Euro car parts list 2 depending on engine number.
    Will have a look at my car pass and the engine itself.
  1. Z19DTH ECU location
    By cont1204 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 12:36
  2. boot fuse location and number ( if possible)
    By valhalla in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 14:27
  3. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  4. Z19DTH starter motor part number?
    By damers2000 in forum Engine & Drivetrain
    Last Post: 24th June 2012, 09:01
  5. 2.2 Direct Engine Number Location
    By Palmo in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2008, 00:35
1.9 cdti engine number location
vauxhall engine number location
where to find engine number on a vectra c
vectra c engine codes
vectra engine code location
z19dt engine no.location
engine number location vectra c
engine number location signum 2.2
finding engine number vauxhall signum
engine code location insignia
vectra c engine numer
vauxhall insignia engine code location
where are engine number location on a vauxhall vectra
engine number location astra z19dth
vectra c 1.9 cdti engine number location
1.9 cdti 110kw engine number location
where is engine no on vectra c 1.9 diesel
vectra engine number
z19dt engine number
engine code opel vectra c location
where would i find engine number on vauxhall insignia
how to find engine number for vauxhall vectra 2007 1.9cdti
where to find engine code on vectra c
1.9 cdti engine code
where is the engine code on a vectra c
